I have a number blocks to show the pattern coverage of a selectable candela horn strobe. I have text that shows the candela and attributes to indicate which circuit the device is attached to. I normally use no more that 4 circuits so I have 4 attributes and just select the one I want and type the circuit number in which would be S1, S2, S3, or S4. Would I be better off using a visibility action or a lookup action? I need to show which circuit the device is on with text and also perform a data extraction so I can do my battery calculations and other things. I attached a drawing with the block in it so you can get a better idea of what I'm using.
Horn Strobe.dwg
