drennich
Importing Block: Text Becomes Oblique
drennich
Full AutoCAD 2011. When inserting Obsolete Block the word Obsolete comes in oblique 28 degees, but all the other text remains correct. When opening block as a regular file all text comes in fine. This is only happening to me and not the other drafters. Am I missing a setting somewhere?
Share this post
Link to post
BIGAL
Check your text "Styles" you may have a block with two different text styles. Explode and have a look.
Share this post
Link to post
RobDraw
Post the block and a stripped down file that makes the text oblique.
Share this post
Link to post
drennich
Checked Text Styles and even though they are different, changing them had no effect on the word Obsolete being normal instead of oblique. Only way to change is to insert the block into the drawing and then go into Block Editor and change text under Text Editor/Formatting/Oblique Angle to zero.
Share this post
Link to post
RobDraw
If you post the files, an answer will be forthcoming rather quickly.
Share this post
Link to post
drennich
I guess I don't know what you mean by "post the files". Could you please go into detail? Thanks.
Share this post
Link to post
RobDraw
Upload them to the forum so that we can look at them.
Share this post
Link to post
drennich
Unfortunately I'm a government contractor and can't go about posting government files on a public forum. That would be the way to go otherwise though.
Share this post
Link to post
RobDraw
I did say to post the block and a stripped down version of the file that it is happening in. We don't need to see any project or design information. If you can't do that, you are going to have to provide a lot more information for us to replicate the problem.
Share this post
Link to post
