Hi,
I'm trying to use the LM:writecsv function to export data from blocks to a csv file.
I have made a lisp that selects all the blocks and I'm able to generate a list that has the data I need. What I'm having trouble with is making a list of lists that is needed for the LM:writecsv function.
So far I have this:
(defun C:expcsv()
(setq ssnsccsv (ssget "X" '((0 . "INSERT") (-3 ("vs_carrier*")))))
(setq sscnt 0 sslist nil)
(repeat (sslength ssnsccsv)(setq sslist (cons (ssname ssnsccsv sscnt) sslist))
(setq sscnt (1+ sscnt))
;(while (/= sslist nil)
(setq a (car sslist))
(setq b (cdr sslist))
(setq varcsv1 1)
(setq ssa (ssadd)) ;block ename
(ssadd a ssa)       ;to selection set 'ssa'
(setq koordinatea (cdr (assoc 10 (entget (ssname ssa 0)))))
(setq xkoora (rtos (car koordinatea))) ;x coordinate
(setq ykoora (rtos (cadr koordinatea)));y coordinate
(setq varcsv2 (strcat "POINT (" xkoora " " ykoora ")"))
(setq lista1csv (list varcsv1 varcsv2))
	(setq dada (cdr(car(cdr(assoc -3 (entget a '("vs_carrier*")))))))
		(setq data1 (cdr (nth 0 dada)))
		(setq data2 (cdr (nth 1 dada)))
		(setq data3 (cdr (nth 2 dada)))
		(setq data4 (cdr (nth 3 dada)))
		(setq data5 (cdr (nth 4 dada)))
		(setq data6 (cdr (nth 5 dada)))
		(setq data7 (cdr (nth 6 dada)))
(setq lista2csv (list data1 data2 data3 data4 data5 data6 data7))
(setq listacsv (append lista1csv lista2csv))
);end of defun
The list 'listacsv' contains all the data I need for each block.
So how could I make a loop that takes each block from the selection set, makes a list with the data and then appends the list to a list of lists that I can then use with the LM:writecsv function.
I hope I was clear.
So I need a list for each block and that list should be a row in the csv file.
Here is the link to Lee Mac's LM:writecsv function http://www.lee-mac.com/writecsv.html
Untested, but try...
(defun expcsv ( / ssnsccsv sscnt sslist k a varcsv1 koordinatea xkoora ykoora varcsv2 lista1csv dada data1 data2 data3 data4 data5 data6 data7 lista2csv listacsvrow listacsv )
 (setq k 0)
 (while (setq a (car sslist))
   (setq sslist (cdr sslist))
   (setq varcsv1 (itoa (setq k (1+ k))))
   (setq koordinatea (cdr (assoc 10 (entget a))))
   (setq dada (cdr (car (cdr (assoc -3 (entget a '("vs_carrier*")))))))
   (setq listacsvrow (append lista1csv lista2csv))
   (setq listacsv (cons listacsvrow listacsv))
 );end while
 (reverse listacsv)
);end of defun
(LM:writecsv (expcsv) (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv"))
Edited by marko_ribar
Thank you Marko, I'll try that.
I actually managed to get the list right by adding this line of code.
(setq lst (cons  listacsv3 lst))
So, now i have
(defun C:expcsv()
(repeat (setq in (sslength ssnsccsv))
(setq varcsv1 1)
(setq ssa (ssadd))  ;dodaj ename
(ssadd a ssa);nosaca u ss ssa
(setq xkoora (rtos (car koordinatea))) ;x koordinata
(setq ykoora (rtos (cadr koordinatea)));y koordinata
(setq listacsv3 (append lista1csv lista2csv))
!lst returns:
((1 "POINT (24.6153 -2.2945)" "CFE8C2DD-8F7F-444D-A00F-A883EB319757" 0.0 "1" "1" "2" " 250" "36") (1 "POINT (24.6153 -2.2945)" "CFE8C2DD-8F7F-444D-A00F-A883EB319757" 0.0 "1" "1" "2" " 250" "36") (1 "POINT (24.6153 -2.2945)" "CFE8C2DD-8F7F-444D-A00F-A883EB319757" 0.0 "1" "1" "2" " 250" "36"))
Now I have another problem. When I try to use the LM:writecsv function with 'lst' I get the following error:
Command: EXPORTCSV
LM:CSV-ADDQUOTES
Here is the code I use
(defun c:exportcsv ( / fn in lst ss )
(defun LM:writecsv ( lst csv / des sep )
   (if (setq des (open csv "w"))
           (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
           (foreach row lst (write-line (LM:lst->csv row sep) des))
           (close des)
           t
(defun LM:lst->csv ( lst sep )
   (if (cdr lst)
       (strcat (LM:csv-addquotes (car lst) sep) sep (LM:lst->csv (cdr lst) sep))
(defun LM:csv-addquotes ( str sep / pos )
   (cond
       (   (wcmatch str (strcat "*[`" sep "\"]*"))
           (setq pos 0)
           (while (setq pos (vl-string-position 34 str pos))
               (setq str (vl-string-subst "\"\"" "\"" str pos)
                     pos (+ pos 2)
           (strcat "\"" str "\"")
       (   str   )
I think the problem is that some elements of my list have quotes and some dont. I dont know how to solve that.
I use
(mapcar '(lambda (x) (mapcar '(lambda (x) (cond ((= (type x) 'int) (itoa x)) ((= (type x) 'real) (rtos x)) (T x))) x)) lst)
to put quotes on all elements of the list.
And I use
(LM:writecsv LST (GETFILED "" "" "" 1))
to call the function.
Hvala Marko, ti si se jedini javio. Ne znam u cemu je problem sa ovim forumom ali ljudi ili ne odgovaraju ili su nadrndani.
