Hi everyone,
I have a list with sub lists each containing 18 elements. When the sublists are many say 25, the formation of table take about 20 seconds with the following code:
(setq row 2)
(setq cell 0)
(if lst
 (while lst
   (setq lstx(car lst))
   (while (<= cell 17)
     (vla-settext myTable row cell (car lstx))
     (vla-setCellAlignment myTable row cell acMiddleCenter)
     (setq lstx(cdr lstx))
     (setq cell (+ 1 cell))
     (setq lst(cdr lst))
     (setq row(1+ row))
     (setq cell 0)
Row 0 is the title and 1 contains the headings of columns.
Can this be speeded up by lambda functions and if so how?.
Thanking in advance.
Aloy
Thanks Tharwat. Now less than one second.
Aloy
It may be this that is slowing it down (vla-setCellAlignment myTable row cell acMiddleCenter) setting column to acmiddlecenter not something I have had to do. I did 88 rows and is splat done.
Yes, that is true. It works as fast as with 'regeneratetablesuppressed' option when the formatting is suppressed. There is no worry about the formatting as I am going to export it to Excel where I can do all that.
Thanks BIGAL.
Aloy
Aloy
You are welcome.
