Extruding a element after creating it - newb question
I've wrote the following routine, that creates 2 polygons
(defun c:fuste3d (/ pin altura dsup dinf nlados esp e2)
(setq pin (getpoint "\nPonto de introducao: "))
(setq dinf (getint "\nDiametro inferior: "))
(setq nlados (getint "\nNumero de lados: "))
(setq esp (getint "\nEspessura: "))
(command "polygon" nlados pin "i" (/ dinf 2))
(command "polygon" nlados pin "i" (- (/ dinf 2) esp))
;;extrude and change taper angle
After this, however, I'm trying to extrude the created polygons by giving them a height with the value of "altura" variable.
The problem is that after using the polygon command, i don't wanna select the objects to extrude, but rather, i want the code to assume the extrude to both polygons, and later on change the taper angle to both.
Ok, i've managed to extrude my polygon with the following.
(defun c:fuste3d (/ pin altura dsup dinf nlados esp e2 ss1 pin1 pin2 dext dint)
(command "_polygon" nlados pin "i" (/ dinf 2))
(setq dext (entlast))
(command "_extrude" dext ""  500)
(command "_polygon" nlados pin "i" (- (/ dinf 2) esp))
(setq dint (entlast))
(command "_extrude" dint "" 500)
The problem now is, how to modify the taper angle? I took a look at groupcodes, but when I try to retrieve the group codes of a 3d solid i really get a mess. Does anyone knows where the taper angle is positioned at the groupcodes?
Look at the extrude command options "Taper" is an option when extruding dont do it after.
(command "extrude" (entlast) "" "T" (getreal "enter angle") (getreal "Enter height"))
