Hi All,
I've got this simple lisp made up which draws a square from a center-point. I find this quite handy because alot of the time i need to draw a pad central to a column and using the normal rectangle command, it doesn't let you create it from a center-point, which is a bit annoying. Autocad should have that as an option..
Anyway, the only thing with it is that if i need a 800sq pad for example, i need to enter 400 because it requests 'radius' size. Is it possible to modify it so if i need 800sq i can just enter 800?
If its pretty simple i'd like to do it but if not i can continue to halve my pad sizes and do it that way
(defun c:rre  () (command "polygon" "4" pause "c"))
Explore this thread:
http://www.cadtutor.net/forum/showthread.php?96834-Draw-a-square
EDIT: Or try this:
(defun C:test ( / d AcSpc p CircleObj p1 p3 ll ur )
(initget (+ 1 2 4))
(setq d (getreal "\nSpecify square's size: "))
(setq AcSpc (vlax-get-property (vla-get-ActiveDocument (vlax-get-acad-object)) (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace)))
(setvar 'errno 0)
(while (/= 52 (getvar 'errno))
	(initget 128 "Size") (setq p (getpoint "\nSpecify square's center point or [size]: "))
	(cond
		((and (= 'STR (type p)) (wcmatch p "S*")) (initget (+ 1 2 4)) (setq d (getreal "\nSpecify square's size: ")))
		((and p (listp p))
			(setq CircleObj (vla-AddCircle AcSpc (vlax-3D-point p) (/ d 2.)))
			(vla-GetBoundingBox CircleObj 'll 'ur)
			(mapcar 'set '(p1 p3) (mapcar 'vlax-safearray->list (list ll ur)))
			(entmake
				(append
					(list (cons 0 "LWPOLYLINE")(cons 100 "AcDbEntity")(cons 100 "AcDbPolyline")(cons 90 4)(cons 70 1))
					(mapcar '(lambda (x) (cons 10 x)) (list p1 (list (car p1) (cadr p3)) p3 (list (car p3) (cadr p1))))
			(vla-Delete CircleObj)
		(T (setvar 'errno 52))
);| defun |; (or (vlax-get-acad-object) (vl-load-com)) (princ)
Edited by Grrr
Hi All,
AutoCAD does have this option. POLYGON
Hi All,
(defun c:rre ( / dia )
 (setq dia (getreal "\nEnter diameter... "))
 (setq dia (/ dia 2))
 (command "polygon" "4" pause "c" dia)
About as short as you can get it
(defun c:rre ( )
(command "polygon" "4" pause "c" (/ (getreal "enter dia") 2.0))
Problem solvered!! Cheers guys!
I'm gonna look into working this stuff out for myself one day.. :P
(defun c:rre ( )
Much better BIGAL...
