JEEP Posted October 26, 2016 Posted October 26, 2016 Hi guys and girls, first time posting. I'm trying to calculate a precise volume of sediment that will be added to a beach. That's called beach nourishment. I know it's weird, I'm a geomorphologist. For now, I have drawn six 3d polylines that represents beach profiles. These 3d polylines were drawn from sets of points with x,y and z coordinates. They all have the same reference. Profiles are apart from each other by about 5 meters. Next step I have done is to draw new profile (3d polylines), with the same x and y coordinates but with a higher z value. These new 3d polylines represent the amount of sediment that will be added to the beach. Finally, I linked all those 3d polylines with each other to create a kind of solid. It's a very irregular solid. My question: Is it possible to calculate a volume (m³ of feet³) within these polylines like I would do with the function Area for a 2d polyline? The .dwg is attached to this message. Any help will be greatly appreciated Thanks a lot Beach nourishment_R.1.dwg Quote
BIGAL Posted October 26, 2016 Posted October 26, 2016 1 If you have civ3d then its a button press. 2 Other civil software again button press. 3 There is some free software out there. 4 Find some one with civ3d and get volume. 5 May be able to make a solid from two surfaces. Looking at your dwg your second surface is incorrect it should be smooth and hips and hollows removed. Yes you can use end area and get a reasonable answer (a1+a2)/2 * length. Quote
JEEP Posted October 26, 2016 Author Posted October 26, 2016 Thanks BIGAL, You are right about the second surface. It was a test. The new profiles will be much smoother. Tell me if I'm wrong. In Autocad (not Civil3d), I cannot create a solid from irregular 3dpolylines apart from extruding one of the polylines. I absolutely need Civil 3d if i want to calculate the precise volume of an irregular solid with a Autodesk software. Am I correct? Thanks a lot for your help!! Quote
BIGAL Posted October 26, 2016 Posted October 26, 2016 I think you can create a 3d surface but thats not an area I do much in so just hang in there, the likes of Remark etc will possibly be able to help. Quote
