Hello all,
I am new to this forum but will have many questions in the future.
First of all, i am having problems with solid arrows in a block that has been inserted into a drawing. It is shown solid in paperspace but in plot preview it is not solid. This problem is only on two computers in my office. i have tried all of the system variables for fill text fill, fill model, etc. this problem is not only with the block but with the Title block border as well. To add to this problem, the wipeouts in this drawing are not working.
Please help soon.
Thanks
For the wipeouts, the usual culprit is DRAWORDER, you need to make sure they are above the objects they are meant to conceal.
As for the arrows, I'd check to make sure that they are not set to a numerical color for white, as that would not show up back in the layout.
Draworder is not the issue and as for the block we have been using it for a couple of years now.
Always need to start with the tier one stuff. Have you given it a good AUDIT and PURGE lately?
Perhaps the block is set annotative and inserted in such a way that the arrows are produced at too small of a scale to be seen?
Have you turned the wipeout frames on to ensure they are still in the correct location? Or does the problem exist for new wipeout also.
when you say the Wipeouts are not working, what exactly do you mean?
