hello i need a lisp that change a block or all blocks in a drawing to byblock on layer 0 it is possible?
You need to change BlockReferences or BlockDefiniions?
i need to change block definitions
thanks but i try to load norm-blocks then i can not run it, i write norm-block but there is no command like that
This is LISP-function, not command. Use:
(norm-blocks 1)
oh excuse me.
now i need a macro to change instantly the color of a block.
in normal mode i need write change , select block then select color and then select numer of color...
ok thank you very much you are very kindly good day
but there is a possibility to change temporary the color of a block , only for selection?
