Casio47 Posted November 8, 2016 Posted November 8, 2016 Hello All... I have a rectangle which I've HATCHed. I have a second rectangle inside the first rectangle with the HATCH. The second rectangle I wish to delete the HATCH with in this specific rectangle area, but leave the HATCH of the first rectangle. Basically, get rid of the HATCH in my second rectangle so it is clear. Thanks AutoCAD 2016 Quote
ReMark Posted November 8, 2016 Posted November 8, 2016 I would just erase all the hatch pattern and redo it (pick in the space between the two rectangles). Hatch > Pick internal point or.... If that seems like way too much work for you then use the WIPEOUT command (polyline option). Quote
rkent Posted November 8, 2016 Posted November 8, 2016 Trim command works with Hatch, depending on the release of AutoCAD you have. Quote
Rewind Posted November 8, 2016 Posted November 8, 2016 As rkent said. The trim command works best for me. Quote
Casio47 Posted November 9, 2016 Author Posted November 9, 2016 So I'm doing something wrong with the trim command. The problem with wipe out is it deletes everything. On Trim, I select my rectangle with the hatch, but when I hover over the hatch area I want to get rid of, it tells me I cant trim this object (hatch) Quote
rkent Posted November 9, 2016 Posted November 9, 2016 Please tell us what version of AutoCAD you are using, it really helps since things are added over time. There is a place for that in your profile above your Location and Join Date. Quote
Casio47 Posted November 9, 2016 Author Posted November 9, 2016 OK, I did that, im on 2016 AutoCAD Quote
rkent Posted November 9, 2016 Posted November 9, 2016 create a small drawing duplicating the objects and the hatch and post here please. Quote
ReMark Posted November 9, 2016 Posted November 9, 2016 The wipeout would only obscure, NOT DELETE, everything if it were applied to the larger of the two rectangles. Place the wipeout where it belongs around the perimeter of the smaller (inner) rectangle. Quote
iconeo Posted November 10, 2016 Posted November 10, 2016 You could also edit hatch and then add an object. Sent from my SM-G920T using Tapatalk Quote
