Cylis0509 Posted November 9, 2016 Posted November 9, 2016 Hi everyone, So I have LISP I am trying to modify. The code below is a snippet from there. Right now I have a dialog (dcl) and when you select from a drop down it populates a list with the name of the slides in that folder and removes the .sld. Which is good but I also need it to remove the first 22 characters from the slide name. Every slide starts with a 19 character ID followed by a space dash space, written description and description varies in length. Slide name example: 1234-5678-9101-2345 – Written Description(length varies) So in my list it should show only: Written Description(length varies) I am also looking for the inverse of this as well. I have another section which has a boxed column with a label and I need that text to be only the first 19 characters from the slide name. So my label should look like this using the same example above: 1234-5678-9101-2345 Any help would be greatly appreciated. (defun subcat_action (val) (if (/= val nil) (progn (if (setq blklst (vl-directory-files (strcat projectpath-sub "\\"(nth (read (get_tile "subcat")) subcatlst)"\\") "*.sld")) (progn (setq blkstmp ()) (foreach n blklst (setq blkstmp (append blkstmp (list (vl-string-right-trim ".sld" n))))) (mode_tile "blknm" 0) (start_list "blknm") (mapcar 'add_list blkstmp) (end_list) (set_tile "blknm" "0") (setq val3 "0") (blknm_action "0") ) (progn (setq blkstmp (list " No Details found ! ")) (start_list "blknm") (mapcar 'add_list blkstmp) (end_list) ))))) Quote
tombu Posted November 9, 2016 Posted November 9, 2016 (substr n 1 19) and (substr n 23) should give you the slide name and the description respectively. Quote
Roy_043 Posted November 9, 2016 Posted November 9, 2016 (substr "abc - def" 1 3) => "abc" (substr "abc - def" 7) => "def" If the position of " - " is variable you can find it using: (vl-string-search " - " "abc - def") => 3 Note: substr is one-based (first character is index 1), vl-string-search is zero-based. Quote
Lee Mac Posted November 9, 2016 Posted November 9, 2016 (defun SlideID ( sld ) (substr sld 1 19)) (defun SlideDescription ( sld ) (substr (vl-filename-base sld) 23)) _$ (setq sld "1234-5678-9101-2345 – Written Description(length varies).sld") "1234-5678-9101-2345 – Written Description(length varies).sld" _$ (SlideID sld) "1234-5678-9101-2345" _$ (SlideDescription sld) "Written Description(length varies)" ( EDIT: too slow ) Quote
Cylis0509 Posted November 9, 2016 Author Posted November 9, 2016 (defun SlideID ( sld ) (substr sld 1 19)) (defun SlideDescription ( sld ) (substr (vl-filename-base sld) 23)) _$ (setq sld "1234-5678-9101-2345 – Written Description(length varies).sld") "1234-5678-9101-2345 – Written Description(length varies).sld" _$ (SlideID sld) "1234-5678-9101-2345" _$ (SlideDescription sld) "Written Description(length varies)" ( EDIT: too slow ) This looks great Lee and makes sense. I am just not sure how to incorporate into existing code. This is not my original code. I am modifying someone else's. Don't want to muck it up. Quote
