I am now using 2017. I usually have the properties parked on the side so that I can click on an entity and see all the properties. But in Properties under Geometry there is no rotation angle. Is it gone in 2017 or is there a way to get it back? Thanks.
You didn't happen to select more than one entity did you?
No, but even if I did it would say "varies" and at the top it would say 2 items under selection, or however many. even when nothing is selected I should see all the catagories but I don't see rotation angle.
Unfortunately I am working remotely today and don't have access to my office computer that runs 2017. Currently using a laptop running 2015. I'm sure someone else will come along shortly who may have an answer for you. As far as I know users cannot pick and choose what properties are displayed on the Properties Palette. However, in the meantime you can activate Quick Properties and customize the display (very easily) to indicate angle.
What are you selecting? All objects do not necessarily give a rotation angle in 2011 either.
Ok, I see now that only lines not polylines list an angle. It must be Friday, Im ready for the weekend! Thanks SLW210.
