gmmdinesh Posted November 14, 2016 Posted November 14, 2016 Hi all. I need one more help. I have one rectangle block, when i insert the block in model space, the layout should be create in automatically for that block covered area. I want lisp to create layout automatically when i insert rectangle block. Some one help me? Thanks in advance. Regards Dinesh P Quote
pBe Posted November 14, 2016 Posted November 14, 2016 Saving a VIEW for the rectangle block is as good as inserting that view on layout tab. For this requirement try exploring Sheet Set It is as easy as dragging the Sheet View to create layout on Paper space. Quote
BIGAL Posted November 15, 2016 Posted November 15, 2016 If you simply pick a centre point of your rectang you can use zoom center scale to set the viewport. 1 have a title block in a layout have a mview already created scale not important, manual steps are next can be automated and there was a post very recently including lisp code. Command: ID Specify point: X = 132.596 Y = 141.444 Z = 0.000 centre of rectang Command: picked layout Regenerating layout. Regenerating model. Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: *Cancel* Command: _.MSPACE Command: Z ZOOM Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : e Command: Z ZOOM Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : c Specify center point: 132.596,141.444 Enter magnification or height : 4xp for us thats 1:250 Grab grips and size to suit Quote
gmmdinesh Posted November 15, 2016 Author Posted November 15, 2016 Hi. Thanks for your reply. I understand what you say. but i need automation program...here i attached a dwg file. in this file, in model space i insert a rectangle block 001, 002.(block created from viewport). When i insert the block the layout is automatically create for that respective block. ( for example 001 block-->SHT-001 A3a) can you understand...? 95518671.DWG Thanks again. Regards Dinesh P Quote
