Set all blocks in a drawing to be unexplodable?
I've written routines before that use ssget and chprop to alter drawings with massive amounts of objects before, but not sure I can use this same style to set all blocks in a drawing to be unexplodable.
Is there a way I could write a simple script in AutoLISP that would set "allow exploding" to no for all blocks in a drawing? Any info leading me in the right direction would be appreciated, thanks!
(defun C:test ( / )
(vlax-for b (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
	(and
		(eq (vla-get-IsLayout b) :vlax-false)
		(vl-catch-all-apply 'vla-put-Explodable (list b :vlax-false))
) (vl-load-com) (princ)
I would also exclude xrefs, i.e.:
(defun c:unexplodeall ( )
   (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
       (if (and (= :vlax-false (vla-get-islayout blk))
                (= :vlax-false (vla-get-isxref   blk))
           (vla-put-explodable blk :vlax-false)
@Grrr, I don't see the need for vl-catch-all-apply in this operation?
I've included it "just in case", no specific reason. :)
Some interesting questions, related to this thread:
- I don't understand why the "Layout blocks" also have "Explodable" property, how could one explode the Model/Paper space?!
- Also I was curious how it can be done with vanilla lisp, so I checked in the "BLOCK" (dxf) reference, expecting to find the explodable flag under GC 70, but no documentation about it.
OK, but that's a slippery slope - continuing with that form of error trapping & logic, you might as well enclose the entire program within a single vl-catch-all-apply expression: the code would never noticeably return an error, and when it does error, nothing is handled appropriately.
Because they are derived from the same class as blocks & xrefs, and so all have the same properties.
Example:
(defun getexplodable ( blk / ent )
   (if (setq ent (tblobjname "block" blk))
       (cdr (assoc 280 (entget (cdr (assoc 330 (entget ent))))))
I've read that before, but I don't think it should be a problem for this particular case (routine).
BTW I think in some cases manual prompting might be useful:
(if (vl-catch-all-error-p (setq err (vl-catch-all-apply ...)))
(setq errLst (cons err errLst))
(and errLst
(print "The following errors occured: ")
(foreach x errLst (print (vl-catch-all-error-message x)))
Example:
Thanks alot!
I've just read about GC 330, its written that its "Soft-pointer handle" - is that some type of dictionary for that entity?
The value of DXF group 330 is generally a pointer to the parent entity - in this case, the BLOCK_RECORD parent of the BLOCK entity.
Thanks Lee!
