Romero
Multiple selection to change color
Romero
Hello, I am new to the forum.
Can anyone of you help me?:cry:
I am a beginner in lisp codes.
My problem is that I need to do multiple selection to change color.
I can only do it once :(
Also that you can select the objects and then apply the command:glare::glare:
(DEFUN c:CBB () (COMMAND "CHANGE" PAUSE "" "P" "C" "BYBLOCK" ""))
(DEFUN c:CBL () (COMMAND "CHANGE" PAUSE "" "P" "C" "BYLAYER" ""))
(DEFUN c:C1 () (COMMAND "CHANGE" PAUSE "" "P" "C" "1" ""))
(DEFUN c:C2 () (COMMAND "CHANGE" PAUSE "" "P" "C" "2" ""))
(DEFUN c:C3 () (COMMAND "CHANGE" PAUSE "" "P" "C" "3" ""))
(DEFUN c:C4 () (COMMAND "CHANGE" PAUSE "" "P" "C" "4" ""))
(DEFUN c:C5 () (COMMAND "CHANGE" PAUSE "" "P" "C" "5" ""))
(DEFUN c:C6 () (COMMAND "CHANGE" PAUSE "" "P" "C" "6" ""))
(DEFUN c:C7 () (COMMAND "CHANGE" PAUSE "" "P" "C" "7" ""))
Share this post
Link to post
Grrr
Hi, you mean like this but not temprarily ?
Share this post
Link to post
Romero
It's just what i need
But without the temprarily
How to remove the temparily color?
Someone help me :cry:
Share this post
Link to post
Grrr
The above code in the #22 post does just that, both are written by Lee Mac.
Share this post
Link to post
