Removing password protection
I have a dwg with a vaild password, so I can open the file.
However I want to save the file with the protection removed.
Found these instructions on how to do this .....
minus.gifTo remove a password from a drawing
  1. Click Tools menu ac.menuaro.gif Options.At the command prompt, enter options.
  2. In the Options dialog box, Open and Save tab, click Security Options.
  3. In the Security Options dialog box, Password tab, clear the Password or Phrase to Open This Drawing option.
  4. Click OK.
Unfortunately there is no password tab in the Security Options dialogue box, so I am a little bit stuck.
Any ideas ?
If Rob's suggestion doesn't work, try to WBLOCK it, or SAVEAS a .dxf file, or to a much earlier .dwg file type which might predate the password protection feature?
Edited by Dadgad
I believe that once you have done that, you can resave your .dxf, as a .dwg file, then I suspect you will be good to go.
Glad that worked for you. :beer:
