Hello there, I am new here and i am looking for solution in my dynamic block for a while. I ve got a problem with an arc center. When you are stretching the door the center moves down (or up depends how are the doors rotated).
And that is not the only problem, when you are stretching the thickness of the wall in the block editor everything works great but when you close the editor and try this action in drawing it missbehave. Thanks for suggestion and time guys.
doors.dwg
The problems you are having are because your geometry is not based on the insertion point, try moving everything to 0,0 in the block, if you need to insert in the center of the wall you would be better of using e separate basepoint
