i know this is probably very easy for you guys. but could you help me build a lisp to multiple select LINES and change the angle?
if angle
if angle > 270, we sub - 180 to the angle
heres what i got so far...
(defun c:anglefix ( / d e f i s spt ept)
   (if (and (setq s (ssget '((0 . "LINE"))))
           (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i))))
spt (cdr (assoc 10 e))
ept (cdr (assoc 11 e))
i dont know how to use read the angle and change it
What is the difference between adding 180 degrees and subtracting 180 degrees?
Aren't they the same thing?
89 + 180 = 269
271 - 180 = 91
it has something to do with the angle when extracted...
i need the angle to be BETWEEN 90 and 270 ONLY
thus,
if angle
if angle >270 i sub -180
You want to rotate every line around its center?
Do you need to learn from the code?
yes! and yes! i do wanna learn
Alright:
[b][color=BLACK]([/color][/b]defun c:anglefix [b][color=FUCHSIA]([/color][/b] / DTR RTD mid SS i e enx o spt ept cen ang [b][color=FUCHSIA])[/color][/b] [color=#8b4513]; localise the used defuns and set[b][color=FUCHSIA]([/color][/b]ted[b][color=FUCHSIA])[/color][/b] q[b][color=FUCHSIA]([/color][/b]uotes[b][color=FUCHSIA])[/color][/b][/color]
[color=#8b4513]; define some functions to help for the task:[/color]
[b][color=FUCHSIA]([/color][/b]defun DTR [b][color=NAVY]([/color][/b]a[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]* PI [b][color=MAROON]([/color][/b]/ a 180[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][color=#8b4513]; converts degrees to radians[/color]
[b][color=FUCHSIA]([/color][/b]defun RTD [b][color=NAVY]([/color][/b]a[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]/ [b][color=MAROON]([/color][/b]* a 180[b][color=MAROON])[/color][/b] PI[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][color=#8b4513]; converts radians to degrees[/color]
[b][color=FUCHSIA]([/color][/b]defun mid [b][color=NAVY]([/color][/b]p1 p2[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]mapcar [b][color=MAROON]([/color][/b]function [b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]a b[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]/ [b][color=RED]([/color][/b]+ a b[b][color=RED])[/color][/b] 2.[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] p1 p2[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; finds the midpoint between 2 points[/color]
[b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq SS [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [color=#8b4513]; prompt for a SS of lines, if valid then iterate thru it[/color]
	[b][color=NAVY]([/color][/b]repeat [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]sslength SS[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [color=#8b4513]; iterate through the selection set[/color]
			e [b][color=GREEN]([/color][/b]ssname SS [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1- i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; entity[/color]
			enx [b][color=GREEN]([/color][/b]entget e[b][color=GREEN])[/color][/b] [color=#8b4513]; entity's data [b][color=GREEN]([/color][/b]elist[b][color=GREEN])[/color][/b][/color]
			o [b][color=GREEN]([/color][/b]vlax-ename->vla-object e[b][color=GREEN])[/color][/b] [color=#8b4513]; convert the entity into vla-object [b][color=GREEN]([/color][/b]for vla-Rotate[b][color=GREEN])[/color][/b][/color]
			spt [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 enx[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; start point[/color]
			ept [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 enx[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; end point [/color]
			cen [b][color=GREEN]([/color][/b]mid spt ept[b][color=GREEN])[/color][/b] [color=#8b4513]; mid point[/color]
			ang [b][color=GREEN]([/color][/b]angle spt ept[b][color=GREEN])[/color][/b] [color=#8b4513]; angle of the line [b][color=GREEN]([/color][/b]in radians[b][color=GREEN])[/color][/b][/color]
		[b][color=MAROON])[/color][/b][color=#8b4513]; setq[/color]
		[b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]<= 90 [b][color=RED]([/color][/b]RTD ang[b][color=RED])[/color][/b] 270[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; if angle is not between 90 and 270 degrees[/color]
			[b][color=GREEN]([/color][/b]cond [color=#8b4513]; depending on the angle perform the corresponding action, using [b][color=BLUE]([/color][/b]cond[b][color=BLUE])[/color][/b][/color]
				[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]< [b][color=PURPLE]([/color][/b]RTD ang[b][color=PURPLE])[/color][/b] 90[b][color=RED])[/color][/b] [color=#8b4513]; angle is below 90 deg[/color]
					[b][color=RED]([/color][/b]setq ang [b][color=PURPLE]([/color][/b]+ ang PI[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [color=#8b4513]; add 180 degrees [b][color=RED]([/color][/b]value in radians[b][color=RED])[/color][/b] - this line is redundant, unless you want do do calculations[/color]
					[b][color=RED]([/color][/b]vla-Rotate o [b][color=PURPLE]([/color][/b]vlax-3D-point cen[b][color=PURPLE])[/color][/b] PI[b][color=RED])[/color][/b] [color=#8b4513]; rotate the line on +180 degrees, from its center[/color]
				[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]> [b][color=PURPLE]([/color][/b]RTD ang[b][color=PURPLE])[/color][/b] 270[b][color=RED])[/color][/b] [color=#8b4513]; angle is above 270 deg[/color]
					[b][color=RED]([/color][/b]setq ang [b][color=PURPLE]([/color][/b]- ang PI[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [color=#8b4513]; subtract 180 degrees [b][color=RED]([/color][/b]value in radians[b][color=RED])[/color][/b] - this line is redundant, unless you want do do calculations[/color]
					[b][color=RED]([/color][/b]vla-Rotate o [b][color=PURPLE]([/color][/b]vlax-3D-point cen[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]- PI[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [color=#8b4513]; rotate the line on -180 degrees, from its center[/color]
			[b][color=GREEN])[/color][/b][color=#8b4513]; cond[/color]
		[b][color=MAROON])[/color][/b][color=#8b4513]; if[/color]
	[b][color=NAVY])[/color][/b][color=#8b4513]; repeat[/color]
[b][color=FUCHSIA])[/color][/b][color=#8b4513]; if[/color]
[b][color=FUCHSIA]([/color][/b]princ[b][color=FUCHSIA])[/color][/b] [color=#8b4513]; exit cleanly[/color]
[b][color=BLACK])[/color][/b][color=#8b4513]; defun[/color]
[b][color=BLACK]([/color][/b]vl-load-com[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]princ[b][color=BLACK])[/color][/b] [color=#8b4513]; load the visual lisp extensions[/color]
Alright:
why doesnt it rotates the lines greater that 270?? does it have something to do with this code?
	(command "aunits" 0 "" ""
	 "angdir" 1 "" ""
	 "angbase" 270 "" ""
	 "insunits" 6 "" "")
beause i always set it to meters and due North for the Direction
	 "angdir" 1 "" ""
	 "angbase" 270 "" ""
	 "insunits" 6 "" "")
Hmm, try with "angdir" 0.
0 Counterclockwise
1 Clockwise
And "angbase" 0.
BTW do you use UCS, or work on WCS only ?
UCS...
i cannot change my angdir and angbase, because all of our DWG file have to be on that setup.
UCS...
Try this then:
[b][color=BLACK]([/color][/b]defun c:anglefix [b][color=FUCHSIA]([/color][/b] / DTR RTD mid *error* Svars SS i e enx o spt ept cen ang [b][color=FUCHSIA])[/color][/b] [color=#8b4513]; localise the used defuns and set[b][color=FUCHSIA]([/color][/b]ted[b][color=FUCHSIA])[/color][/b] q[b][color=FUCHSIA]([/color][/b]uotes[b][color=FUCHSIA])[/color][/b][/color]
[b][color=FUCHSIA]([/color][/b]defun *error* [b][color=NAVY]([/color][/b]m[b][color=NAVY])[/color][/b]
	[b][color=NAVY]([/color][/b]and Svars [b][color=MAROON]([/color][/b]mapcar 'setvar [b][color=GREEN]([/color][/b]mapcar 'car Svars[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]mapcar 'cdr Svars[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [color=#8b4513]; Restore the system variables[/color]
	[b][color=NAVY]([/color][/b]and m [b][color=MAROON]([/color][/b]print m[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ[b][color=NAVY])[/color][/b]
[b][color=FUCHSIA])[/color][/b][color=#8b4513]; defun *error*[/color]
[b][color=FUCHSIA]([/color][/b]setq Svars [color=#8b4513]; store the system variables into assoc list, where each item is [b][color=NAVY]([/color][/b]<varName> . <varVal>[b][color=NAVY])[/color][/b][/color]
	[b][color=NAVY]([/color][/b]mapcar '[b][color=MAROON]([/color][/b]lambda [b][color=GREEN]([/color][/b]x[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]cons x [b][color=BLUE]([/color][/b]getvar x[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
		'[b][color=MAROON]([/color][/b][color=#2f4f4f]"AUNITS"[/color] [color=#2f4f4f]"ANGDIR"[/color] [color=#2f4f4f]"ANGBASE"[/color][b][color=MAROON])[/color][/b]
[b][color=FUCHSIA])[/color][/b][color=#8b4513]; setq Svars [/color]
[b][color=FUCHSIA]([/color][/b]and Svars [b][color=NAVY]([/color][/b]mapcar 'setvar [b][color=MAROON]([/color][/b]mapcar 'car Svars[b][color=MAROON])[/color][/b] '[b][color=MAROON]([/color][/b]0 0 0[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; set new values for the variables[/color]
			spt [b][color=GREEN]([/color][/b]trans [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 10 enx[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] 1 0[b][color=GREEN])[/color][/b] [color=#8b4513]; start point, coordinate translated from WCS to UCS[/color]
			ept [b][color=GREEN]([/color][/b]trans [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 11 enx[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] 1 0[b][color=GREEN])[/color][/b] [color=#8b4513]; end point, coordinate translated from WCS to UCS[/color]
[b][color=FUCHSIA]([/color][/b]and Svars [b][color=NAVY]([/color][/b]mapcar 'setvar [b][color=MAROON]([/color][/b]mapcar 'car Svars[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]mapcar 'cdr Svars[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; Restore the system variables[/color]
I don't use often trans, so I might be confused and if the code doesn't behave as expected you might need to switch the values like
(trans .... 0 1) instead of the current (trans .... 1 0).
Not heavily tested but an alternative approach
(defun c:anglefix (/ object lineAngle tmpPoint)
 (setq object (vlax-ename->vla-object (car (entsel))))
 (setq lineAngle
 (angle
   (vlax-curve-getFirstDeriv object 0.0)
   '(0 0 0)
 (if
   (and
     (> lineAngle (* pi 0.5))
     (< lineAngle (* pi 1.5))
     (setq tmpPoint (vla-get-StartPoint object))
     (vla-put-StartPoint object (vla-get-EndPoint object))
     (vla-put-EndPoint object tmpPoint)
I would suggest the following:
([color=BLUE]defun[/color] c:fliplines ( [color=BLUE]/[/color] ang i p q s x )
   ([color=BLUE]setq[/color] ang
       ([color=BLUE]eval[/color]
           ([color=BLUE]list[/color] '[color=BLUE]lambda[/color] '( a b )
               ([color=BLUE]list[/color] '[color=BLUE]rem[/color]
                   ([color=BLUE]list[/color] '[color=BLUE]+[/color] [color=BLUE]pi[/color] [color=BLUE]pi[/color]
                           ([color=BLUE]if[/color] ([color=BLUE]zerop[/color] ([color=BLUE]getvar[/color] 'angdir)) '[color=BLUE]+[/color] '[color=BLUE]-[/color])
                           ([color=BLUE]list[/color] '[color=BLUE]-[/color] '([color=BLUE]angle[/color] a b) ([color=BLUE]getvar[/color] 'angbase))
                   ([color=BLUE]+[/color] [color=BLUE]pi[/color] [color=BLUE]pi[/color])
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] '((0 . [color=MAROON]"LINE"[/color]))))
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s))
           ([color=BLUE]setq[/color] x ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i))))
                 p ([color=BLUE]assoc[/color] 10 x)
                 q ([color=BLUE]assoc[/color] 11 x)
           ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]cos[/color] (ang ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] p) 0 1) ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] q) 0 1))))
               ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 11 ([color=BLUE]cdr[/color] p)) p ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 10 ([color=BLUE]cdr[/color] q)) q x)))
   ([color=BLUE]princ[/color])
Thank you sir LEE!
and thank you to sir Grrr! thank you for teaching me some
Atleast now I know it had to be (trans .... 0 1).
:ouch:
Thank you sir LEE!
You're welcome. :)
:ouch:
Indeed, LINE endpoints are stored relative to WCS and would otherwise be projected to the current UCS plane if not transformed before calculating the angle.
Though, I suspect the issue in this particular case was more a result of the OP measuring the angle relative to the local ANGBASE/ANGDIR settings.
so it does something to do with our setup on angbase and angdir?... good to know! i thought angles read the same lol
It depends how you are measuring them - i.e. whether you are measuring the angle clockwise/counterclockwise (ANGDIR) relative to the WCS/UCS X-axis and respecting ANGBASE or not.
