jim78b Posted December 5, 2016 Posted December 5, 2016 I do not know if it's the right section. I would like in model space see all of one colore..es: purple, but when i edit in place a block the colors of the block will return to the normal color, or when I select a dimensionor or element lines appear the right color. I tried to edit the plot styles but nothing. Quote
ReMark Posted December 5, 2016 Posted December 5, 2016 Your question is confusing. Please clarify. When you are in model space you want to see all objects that are color: purple or you want all objects to be assigned the color purple regardless of what color has been assigned to the layer? When you plot you want everything to be the color purple or do you want to plot only the objects that are purple? Are you looking for a custom lisp program to help you with any of the above? Quote
jim78b Posted December 5, 2016 Author Posted December 5, 2016 Your question is confusing. Please clarify. When i am in model space i want to see all objects that are color: purple When i edit a block in place i want to see it in original color .example:if i set a block byblock purple when i will edit it i want to see the original color of block. Are you looking for a custom lisp program to help you with any of the above?:yes Quote
tombu Posted December 5, 2016 Posted December 5, 2016 Your question is confusing. Please clarify. When i am in model space i want to see all objects that are color: purple When i edit a block in place i want to see it in original color .example:if i set a block byblock purple when i will edit it i want to see the original color of block. Are you looking for a custom lisp program to help you with any of the above?:yes Doesn't work that way if objects in a block are set to byblock then in the insertions they will be whatever the color the insertions are set to. You could have 10 insertions set to 10 colors. When editing the block those colors are not self-referenced so they have no set color. Quote
jim78b Posted December 6, 2016 Author Posted December 6, 2016 I thought there was a certain method, anyway thanks Quote
Roy_043 Posted December 6, 2016 Posted December 6, 2016 Maybe something like this is possible with xrefs and the XREFOVERRIDE variable. But I don't think this variable is available in AC 2013. Quote
jim78b Posted December 6, 2016 Author Posted December 6, 2016 Maybe something like this is possible with xrefs and the XREFOVERRIDE variable. But I don't think this variable is available in AC 2013. oh yes there is not present in 2013 Quote
