My crosshairs do not appear in modelspace. The display setting is set at 100% and the background color is set differently than the crosshairs. Any suggestions?
Are you sure you have a functioning mouse?
What does it say under Current Pointing Device on the System tab?
ReMark,
Yes, the mouse is functioning. I can activate commands outside of the modelspace display, just not within it.
What is indicated in Display > Colors for the color of the background (model space) and the crosshairs?
Have you tried:
Closing and then reopening AutoCAD?
Closing all programs, shutting down then executing a cold reboot?
Disconnecting and reconnecting the plug on the mouse at the back of the computer? Maybe even give the plug a quick blast with compressed air.
ReMark,
I have tried all of the above including reinstalling the software but the problem is still there. I appreciate the pointers. Thanks.
Reinstalling what software? Jeez, I hope you don't mean the CAD program. I would have tried the Repair option first.
When did the problem first occur? Did the crosshairs ever display?
The CAD software was installed on a 'clean' computer. The problem started when the software was installed. It did not work properly upon installation, so I reinstalled it. This did not dolve the problem. I had this software installed on another computer and had no problems.
Hey, did you get this working. If not post and I will try to walk thru your problem on my machine.
W
