richyrich0000 Posted December 12, 2016 Posted December 12, 2016 hi there can anyone help i am trying to achieve a random round hatch pattern as pdf attached using 5 different size holes, the attached pdf shows the part being 200 x150 and i need to achieve that but on a bigger scale to be 1500 x 600 with same size holes any ideas? thanks Rsl110-62.pdf Quote
richyrich0000 Posted December 12, 2016 Author Posted December 12, 2016 im drawing up in autocad, but main aim is to load it into peps to create a cnc punch program Quote
RobDraw Posted December 12, 2016 Posted December 12, 2016 hi therecan anyone help i am trying to achieve a random round hatch pattern FYI, by definition, a pattern cannot be random. Quote
BIGAL Posted December 12, 2016 Posted December 12, 2016 It can be done and has been asked before using a random number generator for the x,y position then check if new circle touches an existing circle if so skip and in your case change circle size and continue, just need a limit to a repeating defun so the area is filled. Do a search using random, pretty sure I posted some code. Quote
nukecad Posted December 13, 2016 Posted December 13, 2016 Are you thinking of this one BIGAL? (I remembered it was for the LISA telescope which made it easy to search). Looks like it could be a start anyway. http://www.cadtutor.net/forum/showthread.php?93660-How-to-generate-an-array-of-randomly-spaced-dots I seem to also remember another one that had random different sized holes drilled through a block at different angles?? Quote
BIGAL Posted December 13, 2016 Posted December 13, 2016 Thanks nukecad thats the one I had in mind. Never got around to stage 2 check for overlapping, also need keep changing radius. Quote
