Pounce Posted January 10, 2009 Posted January 10, 2009 First post, be kind please. I have a new client that needs his work done in AutoCad so I went a bought a copy figuring it would be easy to use as I'm the full bottle on Solidworks and use it for all other clients works. I have a job that needs doing so I'm hoping someone can give me a quick and easy answer to this question. Courses in AutoCad don't start for another 4 weeks and the client needs this first job done by next week. They have supplied me with a copy of their standard AutoCad template for engineering drawings (.dwt files), so I'm hoping there is a way to import a .dxf or .dwg file (saved from Solidwroks) into their template. Is it possible to do this and adjust layers (dimensions and drawing need to be on different layers) after import? Thanks in advance for any help you can provide. Quote
skipsophrenic Posted January 10, 2009 Posted January 10, 2009 should be alright especially iff it's in dwg format. just be warned a conversion from one cad software to another can play silly's with the cad program. E.G. Drawing from Microstation into autoCAD forget's the difference between model space and layout tabs, everything is put into model to scale Quote
Pounce Posted January 10, 2009 Author Posted January 10, 2009 Thanks skip, but I'm a total n00b on AutoCad, so I need to know how to do it, quick, easy and dirty if need be, until I get the course under my belt. Quote
MaxwellEdison Posted January 10, 2009 Posted January 10, 2009 Just spend any time you can spare looking over tutorials (Google "ACAD"+"Beginner"+"Tutorial") Better to spend the time learning the basics. Anything you do quick and dirty will just be that much more difficult to work with down the line. If you have any conventional drafting experience, start by treating ACAD as just another tool in your cabinet and you'll be off to a good start. Quote
skipsophrenic Posted January 10, 2009 Posted January 10, 2009 From what little bit of checking i've done, you should be able to open a dxf file in AutoCAD, there may be a bit of editting needing to do to the file, but the basic data of the drawing itself will be there hopefully. Quote
Pounce Posted January 10, 2009 Author Posted January 10, 2009 Yep, I have no problem opening .dxf or .dwg files, got that bit sussed. What I need to do more or less straight away is this. They have supplied me with a copy of their standard AutoCad template for engineering drawings (.dwt files), so I'm hoping there is a way to import a .dxf or .dwg file (saved from Solidworks) into their template. If I can get this done easily and out of the way, I can focus more on learning the software the correct way. Quote
skipsophrenic Posted January 10, 2009 Posted January 10, 2009 try this. INSERT > XREF Go to where the dxf/dwg is stored. select it click "Open" once its in, type XREF in, and in the dialogue box that pops up, there should be an icon with the dwg/dwf's name next to it. Right click that and click "Bind" That should bring it in for you. If that doesn't work. post back here and I'll do a bit more info hunting Quote
Raggi_Thor Posted January 10, 2009 Posted January 10, 2009 Maybe step by step like this? 1) Create a new drawing based on your client's template, use the command NEW in AutoCAD or just double click the DWT file in Windiws Explorer. 2) Save your dwg. 3) Attach your dwg/dxf from SW as an XREF or 3b) Insert it as asblock (meny Insert/Block and Browse to find it). With INSERT you place acopy of your SW export in the new dwg. With XREF you place a link, so you have to send both files to the client. Quote
Pounce Posted January 11, 2009 Author Posted January 11, 2009 Thanks fellas, that worked to a deegree. I'll see if I can get away with it. Still having a bit of trouble changing layers because I imported it already dimensioned. Might have to redo it and dimension it in AutoCad. Appreciate the time and help. Quote
dbroada Posted January 11, 2009 Posted January 11, 2009 have you tried DXFIN as a command? It may no longer be valid as you can now open a DXF file directly but it always used to work. Quote
Raggi_Thor Posted January 11, 2009 Posted January 11, 2009 I thinkk xref as you suggested is a good advice. Then the sw file will be a reference and people will not notice it's maybe a lot of short lines atc. Quote
stevsmith Posted January 11, 2009 Posted January 11, 2009 is it the 3d model you want to import? or is it just the sw drawing into AutoCAD? Quote
Pounce Posted January 16, 2009 Author Posted January 16, 2009 Me again. Here is a sample of the dwt and a dxf file I'm trying to work with. If someone is able to have a go at it and help point out what I'm doing wrong, you can have my everlasting gratitude. Thanks. Edit.It seems I need 9 posts or more. If I could PM it to someone? Quote
tkelly Posted February 4, 2009 Posted February 4, 2009 Complete the drawing in solid works with 1:1 scale. Save the file as dwg Open the drg in autocad.You can apply layers & can do necessary changes.You are doing this in model of autocad. Shift to the layout mode.Arrange the templete given by client. Make a viewport within templete. Fit the drg in viewport with suitable scale. Tom Kelly, Quote
