Good day
Is there a lisp for construction line...line straight in type the command for vertical/hirizontal line...
Im just being lazy typing 3 letters..
Thnaks in advance
Why stop there? Did you know it is possible to use voice recognition software to create/edit a drawing in AutoCAD? Take the ultimate step and go "hands free".
Xline vertical / horizontal can do it in 2 keystrokes and 1 mouse action. XV or XH
+1 to Halam. Type "XL" enter and select direction. ;)
I personally don't use xlines them that much I suppose. One letter keystrokes are 1,2,3 ..:)
I guess mind control is the next evolutionary step then?
Thats way toooo..... helpful...boinks:D
I got it to 1 like Halam
(defun c:1()(command "xline" "H" pause))
(defun c:2()(command "xline" "V" pause))
I used to have various construction line macros on a set of menu buttons,
Horizontal, vertical, both, 45 & 135 degrees, isometric (30,60,-30,-60), perpendicular to a picked line, angled, offset.
Click the button, (enter angle or offset if needed), pick your point.
Here are the macros, make your own buttons and icons.
^C^C_-layer m construct c red^M^M;_xline h
^C^C_-layer m construct c red^M^M;_xline v
^C^C_-layer m construct c red^M^M;_xline h;\^C_xline v @ ^M^C
^C^C_-layer m construct c red^M^M;_xline a 45;\^C_xline a 135 @^M^C
^C^C_-layer m construct c red^M^M;_xline a 30;\^C_xline a 60 @^M;^C_xline a -30 @^M;^C_xline a -60 @^M^C
^C^C_-layer m construct c red^M^M;_xline a r;\90;
^C^C_-layer m construct c red^M^M;_xline o
...thts works...so grateful to have u guys ...thanks!!!!
