wimal Posted December 16, 2016 Posted December 16, 2016 Cad version 2016. In my cad program above shortcut does not run group on off function. How can I reset it. Quote
YZ Posted December 19, 2016 Posted December 19, 2016 I think you can set this in the CUI, under "Keyboard Shortcuts" > "Shortcut Keys". There is one there called "Group Selection On/Off". Quote
tombu Posted December 28, 2016 Posted December 28, 2016 Ctrl+shift+A is Select Similar on my Civil 3D. Ctrl+A was used to toggle groups in DOS and still works in a macro, but is Windows default Select All everywhere else. I added a flyout to the "Object Snap Cursor Menu" Shortcut Menu named $(eval,OSNAP = $(if,$(and,16384,$(getvar,osmode)),"Off","On")) that has a lot of macros that toggle system variables that update their display automatically. One of those macros toggles Group On/Off. Display Name: $(if,$(and,1,$(getvar,pickstyle)),!.)Group Command Name: Toggle Groups Description: Toggle Group Selection Mode Macro: ^A Another macro toggles Display Group as Box with a single grip at the center Display Name: $(if,$(and,2,$(getvar,groupdisplaymode)),!.)GroupBoxDisplay Command Name: GroupBoxDisplay Description: Display Group as Box with a single grip at the center Macro: ^P'setvar;groupdisplaymode;$M=$(if,$(and,2,$(getvar,groupdisplaymode)),0,2) ^P Quote
tombu Posted December 28, 2016 Posted December 28, 2016 The Keyboard Shortcut to "Toggle Pick Style" which toggles Groups on/off is Ctrl+H If you want it to display and at the command line so you can tell if it's on or off change the macro to ^A Quote
