KrnMhny Posted January 3, 2017 Posted January 3, 2017 Morning all I am currently trying to copy and paste across from one drawing to another; from a survey conducted by an external company to our own construction drawings. I was expecting to have been able to simply Copybase 0,0 and paste to original co-ordinates, which would have overlaid the survey onto our drawings, but this isn't working. When I point ID anything from the survey drawing, the co-ordinates aren't on the same grid as our own construction drawings. As an example, one of the existing traffic lights surveyed by the survey company has these co-ordinates attached; E 430526438.03644 N 570510431.73778 Our own survey of the same traffic light has these co-ordinates; E 430526.273 N 570510.318 As you can see, the first six digits are the same. When I moved the decimal place of the survey co-ords three places to the left, it overlaid onto the survey we had done of the same traffic light fairly accurately, within 200mm. I could go through each point and move the decimal place, but there is so much information on the survey, I would still be working on it at the start of 2018!! I just need to know how to change the survey information to match our own co-ordinate grid. My CAD skills are pretty basic and I'm self taught so I will assume there is a reasonably straightforward solution. I hope this post has made sense. Any help would be greatly appreciated. Thanks Quote
eldon Posted January 3, 2017 Posted January 3, 2017 Make a copy of the external survey drawing (SaveAs and give it another name) and scale the whole drawing about 0,0 with the scale factors of x=0.001, y=0.001 and z=0.001, and save it. You can now copy and paste from this drawing to your own construction drawings. Quote
KrnMhny Posted January 3, 2017 Author Posted January 3, 2017 Thanks for the quick reply. So step by step, this is what I should try; SCALE - SELECT OBJECTS (highlight objects) - SPECIFY BASE POINT (0,0) - SPECIFY SCALE FACTOR (0.001,0.001,0.001) - then copybase 0,0 and paste across as normal? ps. sorry about the laymans CADTUTOR01.dwg Quote
KrnMhny Posted January 3, 2017 Author Posted January 3, 2017 The attached drawing above (CADTUTOR01dwg) is what I have come up with. It seems the survey (multicoloured) is slightly too large and slightly off angle to match in with the kerbs (white). Quote
eldon Posted January 3, 2017 Posted January 3, 2017 You have to bear in mind that the different surveys might have been produced by different methods. The modern survey drawing should have been produced by surveying instruments working directly with GPS to produce Ordnance Survey coordinates. If your construction drawings were produced by using the Ordnance Survey mapping, then there could be up to one metre differences in places, because there is no paper trail as to how the Ordnance Survey mapping was produced. Generally, you have to use a "best fit" alignment, but trust the dimensions on the most recently surveyed drawing. Try investigating X-refs. You would insert the survey company's drawing at 0,0 and with a scaling of 0.001 in x, y and z. You then can move the whole survey drawing in relation to your construction drawings. Quote
KrnMhny Posted January 3, 2017 Author Posted January 3, 2017 How exactly do I change the scales of x,y&z? I need to shrink the size of the survey and it would then fit the kerbline drawing perfectly Quote
eldon Posted January 3, 2017 Posted January 3, 2017 (edited) The way that I would do it is to first of all, open up the external survey drawing. Make sure that all layers are ON and THAWED and UNLOCKED, so that you can see absolutely everything. Then start the SCALE command, either by typing on the command line or picking the command from the Modify menu. Then follow the prompts on the command line, you type what is in red. Command: scale Select Objects: all 4455 found Select Objects: (Return) - this shows that you have finished selecting objects. Specify base point: 0,0 Specify scale factor or [Reference]: 0.001 There you are. Save As the drawing with another name, so you do not get muddled up and also you are keeping the original drawing as it was sent to you. Edited January 3, 2017 by eldon added instruction Quote
KrnMhny Posted January 3, 2017 Author Posted January 3, 2017 That's worked, you Sir, are a gentleman. Sorry for the laymans terms, I'm still pretty raw at this. Thanks for your help, hugely appreciated. Quote
MillerMG Posted January 3, 2017 Posted January 3, 2017 Nice one eldon! Need decimal place moved three spaces. Do this method! lol. Quote
