eyeofnewt555
JPEG Xrefs as Overlay vs Attachment?
eyeofnewt555
Hi all!
So, lets say I have drawing "A" as an xref in drawing "B". I then want to xref drawing "B" in drawing "C". If I don't want "A" to show up in "C", I simply make sure that it's an overlay not an attachment in "B". All good.
Now let's say that there are also a bunch of pictures (jpeg files) xref'd into "B". If I don't want these showing up in "C", there doesn't appear to be the option to make them overlays like with dwg files.
So, is it possible to xref a drawing that has xref'd images without pulling those along too?
Thanks!
Share this post
Link to post
tzframpton
Can you unload them in the XREF manager in File B?
Share this post
Link to post
eyeofnewt555
Yes, and sorry I should have mentioned that. While that is an obvious and relatively pain-free work around, I'd like them to not show up at all. But you're right, I guess worst-case scenario, there's just a few more clicks.
Share this post
Link to post
tzframpton
I thought of a LISP I use from our member alanjt:
http://www.cadtutor.net/forum/showthread.php?47349-XRefsToLayers.LSP-Move-XRefs-to-corresponding-layers
It's a valuable part of my daily LISP routine library but I don't think it'll work with images. I'm going to post in that thread to request if this can be updated to include images and/other items. This may be a good solution too since you can simply Freeze the layer very quickly after running this LISP, and if this is normal workflow that can be embedded in a template, even better.
-TZ
Share this post
Link to post
eyeofnewt555
Thanks! I'll look into it. Appreciate the advice and the request on that forum.
Share this post
Link to post
