muck Posted January 11, 2009 Posted January 11, 2009 Creating a new dimstyle with Annotation dim's in VBA Versioon 2009, VBA Is there a way to create a new dimstyle with annotative dimension in AutoCAD VBA? I think the dimanno variable will have to be 1 but it is a read only variable. The Dimscale variable might have to be 0. I have posted several simular threads on this dimstyle topic but I am finding very little info on this topic form my internet searches. Thank you, Thank you, Quote
ASMI Posted January 11, 2009 Posted January 11, 2009 I can to create annotative dimensions with lisp. I think possible also in VBA but it not easy task because annotation data contains in "ACDB_ANNOTATIONSCALES" extension dictionary. It is loooooooooooooong code to fill this dictionaries by data with VBA. I do not want to do it, but I think that in principle it is possible. You can get and explore all members of this dictionary with lisp function like this: (defun Get_Annotation_Dictionary(vlaObj / aDic) (if(= :vlax-true (vla-get-HasExtensionDictionary vlaObj)) (progn (vlax-for d(vla-GetExtensionDictionary vlaObj) (if(and (vlax-property-available-p d 'Name) (= "ACDB_ANNOTATIONSCALES"(vla-get-Name d)) ); end and (setq aDic d) ); end if ); end vlax-for ); end progn ); end if aDic ); end of Get_Annotation_Dictionary Quote
muck Posted January 11, 2009 Author Posted January 11, 2009 Maybe someone who knows how to do this in VBA might reply to this post. I have found very little in my internet searches. Thank you, Quote
Lee Mac Posted January 11, 2009 Posted January 11, 2009 As ASMI has mentioned in his post - the VBA alternative requires tons of codeing, why not use the simpler LISP method? Quote
muck Posted January 11, 2009 Author Posted January 11, 2009 I guess we have to go with what works. I guess I should use Set objDimStyle = ThisDrawing.DimStyles.Add("stNa") to start with and call up the above rountine aftwards? How would VBA be use to call up the above lisp routine for this. Does anyone have a sample of using VBA - lisp routine to change annotation dim scale Thank you, Quote
muck Posted January 12, 2009 Author Posted January 12, 2009 What about using Sendcommand to make a new dimstyle then change that newly created dimstyle with other variables? Would that work? Quote
muck Posted January 12, 2009 Author Posted January 12, 2009 Maybe something like this but I am going to have to figure out how to give my new dimstyle a unque name for every time I hit the event button. Any suggestions, I am still trying? Private Sub CommandButton5_Click() 'UserForm1.hide 'ThisDrawing.SendCommand "Dimscale" & vbCr 'ThisDrawing.SendCommand "0" & vbCr 'ThisDrawing.SendCommand "*" & vbCr Dim X As Integer X = 5 X = X + 1 Dim DimStyName As String DimStyName = "DimstyleName" DimStyName = DimStyName & Str(X) ThisDrawing.SendCommand "-dimstyle" & vbCr & "AN" & vbCr & "Y" & vbCr & DimStyName & vbCr & "S" & vbCr & vbCr End Sub Maybe I can change a current dimstyle to annotative dim. Any suggestions. Quote
