gS7 Posted January 9, 2017 Posted January 9, 2017 Hi, Is that Possible to create batch file , when double click the file open autocad exe and run lisp file from specified directory ? Please reply Quote
halam Posted January 9, 2017 Posted January 9, 2017 Yes i think this can be done. You can have AutoCAD start up with a lisp program. In combination with windows scripting. But what is the real objective / the tasks that needs to be done, if i may ask? Quote
gS7 Posted January 9, 2017 Author Posted January 9, 2017 Hi halam Thank you for quick reply I have created XXX.lsp , XXX.mnu, XXX.mnl and I want to load menu file directly when open AutoCad (for First time only) so I asked for .Bat file codes and I found a code but its giving error when I run the file start "t" /w "C:\Program Files\Autodesk\AutoCAD 2014\acad.exe" %%V /b "D:\1.scr" Error : cannot find the Specified Drawing file please verify that the file exists Quote
halam Posted January 9, 2017 Posted January 9, 2017 Sorry, i can't help you tith a fully complete answer, i'm not an 'administrator' Bu watch out for the notation of / or // or \ or \\ .. as little help in the direction. https://forums.autodesk.com/t5/autocad-2007-2008-2009/how-can-i-write-a-script-to-add-a-path-to-the-support-file/td-p/2837855 quote (vl-load-com) (setq *files* (vla-get-Files (vla-get-Preferences (vlax-get-acad-object)))) (vla-put-SupportPath *files* (strcat (vla-get-SupportPath *files*) ";C:\\Lisps\\Steel")) ; etc.. Quote
BIGAL Posted January 10, 2017 Posted January 10, 2017 You can load lisps on start up automatically using acaddoc.lsp so could check also for a menu if not loaded, or am I misunderstanding your question. Quote
gS7 Posted January 10, 2017 Author Posted January 10, 2017 runcad.txt or am I misunderstanding your question. Yes Correct Bigal , I have created a .bat file using this code "C:\Program Files\Autodesk\AutoCAD 2012\acad.exe" %%V /b "C:\AutoCADscripts\ScriptName.scr" when I click the batch file AutoCAD Starts and and load the .scr file but it is giving error Error : cannot find the Specified Drawing file please verify that the file exists please help me runcad.txt Found this code in http://www.cadtutor.net/forum/showthread.php?82790-create-batch-file-to-run-script Quote
gS7 Posted January 10, 2017 Author Posted January 10, 2017 roy_043 thank you it is working now ...and how to load a lisp file from known directory with .scr file Quote
