Hi , I am using this lisp a lot of time. I am trying to change the insert text to annotated. The lisp create the annotate text style . The insert text is in the correct text style but is not annotated . Can any one help ???
(defun c:tEST (/ *error* varlist oldvars pt1 tval)
(command "_.-style" "_KEIM" "arial.ttf" "_annotative" "_yes" "_no" 2.5 1.0 0.0 "_no" "_no" "_no")
   (defun *error* (msg)
   (mapcar 'setvar varlist oldvars)
   (if (= msg "")
       (princ "\nText Inserted.")
       (princ "\nEsc or Error Pressed...")
   ) ;_  end if
   ) ;_  end defun
   (setq varlist (list "CMDECHO" "CLAYER")
     oldvars (mapcar 'getvar varlist)
   ) ;_  end setq
   (while (and    (/= (setq pt1 (getpoint "\nSelect Insertion Point: ")) nil)
       (/= (setq tval (getstring t "\nSpecify Text: ")) "")
      ) ;_  end and
   (if (not (tblsearch "Layer" "TEXT"))
       (command "-layer" "m" "TEXT" "")
   ) ;_  end if
   (entmake (list '(0 . "TEXT")
              '(8 . "TEXT")
              (cons 10 pt1)
             (cons 40 (getvar "TEXTSIZE"))
              (cons 1 tval)
              '(50 . 0.0)
              '(7 . "_KEIM")
              '(71 . 0)
              '(72 . 0)
              '(73 . 0)
        ) ;_  end list
   ) ;_  end entmake
   ) ;_  end while
   (*error* "")
) ;_  end defun
It's a crude solution, but it worked for me :P
   ) ;_  end entmake
(command "CHPROP" "last" "" "Annotative" "yes" "")
   ) ;_  end while
Place that command line part in your code between the 'End entmake' en 'end while' and it should work.
The command changes the properties of the last object, and since in this case it's a text you can change the annotative setting.
Hi OMEGA-ThundeR , thank you for the replay. I did the change and worked ,but i want the paper height to be 2.5 no t 2500 ? Any ideas?
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   ) ;_  end setq
      ) ;_  end and
   ) ;_  end if
              '(8 . "TEXT")
              (cons 10 pt1)
              (cons 1 tval)
              '(50 . 0.0)
              '(7 . "_KEIM")
              '(71 . 0)
              '(72 . 0)
              '(73 . 0)
        ) ;_  end list
   ) ;_  end entmake
   ) ;_  end while
   (*error* "")
) ;_  end defun
I'm sorry, but can't help you with any 'annotative' based problems. I never use annotative texts.
You might need to edit some settings within your SCALELISTEDIT though. Or perhaps you need to change the text height in the above code from 2.5 to 0.0025.
Anyway, there seems to be a factor 1000 problem somewhere :).
I told to the code that
so the paper space must be 2.5
I can not understand
If there is any field of expertise i lack it's annotative scales. So i can't be of help on that field :).
Is still not working properly.
This is not the correct way to do this ...
    ) ;_  end entmake
   ) ;_
Why not? It does what was asked right? Set the text object annotative?
What is the problem? You need to change something else too?
When i run the same lisp in the drawing gives me any time other paper space. Tha paper space must be 2.5 all the times. My annotatine scale settings is correct.All the problem is in my code , and i dont know fix it
Can you write out the things you would do manually to achieve the correct settings?
Something like;
- Run TEXT command
- Place text (and give it x.x height and what other settings)
- Go to properties
- Change to annotative
- Set up the right scales
- etc
(defun c:txt2 (/ *error* varlist oldvars pt1 tval)
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   ) ;_  end setq
      ) ;_  end and
   ) ;_  end if
              '(8 . "TEXT")
              (cons 10 pt1)
             (cons 40 0.0125)
              (cons 1 tval)
              '(50 . 0.0)
              '(7 . "_KEIM")
              '(71 . 0)
              '(72 . 0)
              '(73 . 0)
        ) ;_  end list
   ) ;_  end entmake
   ) ;_  end while
   (*error* "")
) ;_  end defun
When i have the scale to 1:1 and run the code works for all scales.
When i change the scale to 1:200 or 1:500 etc and run again the code , all the results are wrong. i want to give the same results with all scales
As far as i can tell there is nothing wrong with the lisp routine. The text is 2.5 high.
You need to add the right scales to the SCALELISTEDIT list.
Then you need to add the right scales (you might have more) to the text you want to show in the viewport.
To set the right scales select the text, go to the properties window and click the smal icon to the right when selecting 'Annotative Scales' (standard 1:1?). Add the scales you want.
Then in paperspace you create a viewport and select that viewport border and set it to the right Annotative scale in the properties window. This is not the same as the viewport scale! (standard scale in properties window).
If you set the SCALELISTEDIT right and set the right scales to the text and viewport it should work. This thread makes me learn more and more about annotative scales :) but it works perfect on my end.
Now is working
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   ) ;_  end setq
      ) ;_  end and
 (command "_.-text" "_justify" "_bl" pt1 "" tval)
   ) ;_  end while
   (*error* "")
) ;_  end defun
  • 2 weeks later...
I found an angle rottation error in the code # 15. Can any one help ?
In the beginnig the code was
              '(8 . "TEXT")
              (cons 10 pt1)
             (cons 40 0.0125)
              (cons 1 tval)
              '(50 . 0.0)
              '(7 . "_KEIM")
              '(71 . 0)
              '(72 . 0)
              '(73 . 0)
        ) ;_  end list
   ) ;_  end entmake
Was angle 90 degrees out, you set it to 0.0 may be need to set the direction and radians from units, these are variables you can set, may be these (SETVAR "LUNITS" 2) (SETVAR "ANGDIR" 0)
