Aftertouch Posted January 11, 2017 Posted January 11, 2017 (edited) Hello all, I got a lot of layers that contain numbers. Example below: B-OI-KL-DATA_KPN_0000546663_VECT_[color="red"]17O000770[/color]-G B-OI-KL-DATA_KPN_0000546663_VECT_[color="red"]17O000771[/color]-G B-OI-KL-DATA_KPN_0000546663_VECT_[color="red"]17O000772[/color]-G B-OI-KL-DATA_LIANDER_0000574962_VECT_[color="red"]17O000770[/color]-G B-OI-KL-DATA_LIANDER_0000574962_VECT_[color="red"]17O000771[/color]-G B-OI-KL-DATA_REGGEFIBER_0000579733_VECT_[color="red"]17O000772[/color]-G The numbers can be completely random, not pre-set. the total list can be up to 100 layers long. I can filter the number using: (vlax-for obj (vla-get-layers doc) (setq lay (vla-get-name obj)) (setq meldingnr "none") (setq meldingsoort "none") (if (wcmatch (strcase lay) "B-OI-*") (progn (cond ((= meldingnr "none") (setq meldingnr (strcat (substr lay (-(strlen lay) 10) 9 ))) ; get number from layer. ) ) <do more stuff with all layers> ) ) This evaluates all layers and does something with it. How can i make a check, that if it gets a number that is not 'meldingnr' it adds it to the 'meldingnr' I am looking for a result that looks like: meldingnr = 17O000770, 17O000771, 17O000772 (can get much longer) (princ meldingnr) Edited January 11, 2017 by Aftertouch Quote
Tharwat Posted January 11, 2017 Posted January 11, 2017 One way with member function; (member 170000771 '(170000771 170000772 170000773)) Quote
Grrr Posted January 11, 2017 Posted January 11, 2017 Or vl-position, or just collect everything and use something from LM's unique & duplicate list functions. Quote
BIGAL Posted January 12, 2017 Posted January 12, 2017 Not sure if this is what you want but there was a post here about missing number 1 3 4 5 "2" is missing. Sorry no idea what its heading was. Quote
Aftertouch Posted January 12, 2017 Author Posted January 12, 2017 I am a bit closer already, i made this: (setq meldingnrlist '()) (setq meldingsoortlist '()) (setvar "CMDECHO" 0) (vlax-for obj (vla-get-layers doc) (setq lay (vla-get-name obj)) (if (wcmatch (strcase lay) "B-OI-*") (progn (setq meldingnr (strcat (substr lay (-(strlen lay) 10) 9 ))) (if(=(member meldingnr meldingnrlist) nil) (progn (setq meldingnrlist (cons meldingnr meldingnrlist)) ) ) (setq meldingsoort (strcat (substr lay (-(strlen lay) 1 ))) (if(= meldingsoort "O") (progn (setq meldingsoort "Oriëntatieverzoek") ) (progn (setq meldingsoort "Graafmelding") ) ) (if(=(member meldingsoort meldingsoortlist) nil) (progn (setq meldingsoortlist (cons meldingsoort meldingsoortlist)) ) ) now i managed to get this: !meldingnrlist = ("17O000770" "17O000771" "17O000772") !meldingsoortlst = ("O") Now i want the add this as a TEXT in the drawing... I tried: (setq nummer (vl-princ-to-string meldingnrlist)) (setq soort (vl-princ-to-string meldingsoortlist)) But then it returns: (17O000770 17O000771 17O000772) (Oriëntatieverzoek) How can i let it look like: 17O000770, 17O000771, 17O000772 (remove the "(" and ")" and add comma's???) Quote
Grrr Posted January 12, 2017 Posted January 12, 2017 (edited) Hint: _$ (mapcar '(lambda (x) (strcat x ",")) '("17O000770" "17O000771" "17O000772")) ("17O000770," "17O000771," "17O000772,") _$ (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) '("17O000770" "17O000771" "17O000772"))) "17O000770,17O000771,17O000772," _$ (vl-string-right-trim "," (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) '("17O000770" "17O000771" "17O000772")))) "17O000770,17O000771,17O000772" _$ BTW, Heres an example how to obtain that "meldingnrlist": (defun GetMeldingnrlist ( / LM:str->lst LayerDef Layers meldingnrlist ) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) (while (setq LayerDef (tblnext "LAYER" (not LayerDef))) (setq Layers (cons (cdr (assoc 2 LayerDef)) Layers)) ) (if (setq Layers (vl-remove-if-not '(lambda (x) (wcmatch x "B`-OI`-KL`-DATA_*_*_*_*`-G")) Layers)) (setq meldingnrlist (vl-string-right-trim "," (apply 'strcat (mapcar '(lambda (x) (strcat (vl-string-right-trim "-G" (last (LM:str->lst x "_"))) ",")) Layers ) ) ) ) ) ) (GetMeldingnrlist) Edited January 12, 2017 by Grrr Quote
Aftertouch Posted January 13, 2017 Author Posted January 13, 2017 Thanks all, I got it working the way i want. The final code: (fragments) (setq meldingnrlist '()) ;Empty list (setq meldingsoortlist '()) ; empty list (if (wcmatch (strcase lay) "B-OI-*") ; check for layer name starting with... (progn (setq meldingnr (strcat (substr lay (-(strlen lay) 10) 9 ))) ; get the meldingnr. (if(=(member meldingnr meldingnrlist) nil); if the number is not in the list.. (progn (setq meldingnrlist (cons meldingnr meldingnrlist)); add it to the list... (setq meldingsoort (strcat (substr lay (-(strlen lay) 1 ))) ; add other info of that layer to other list. (if(= meldingsoort "O") ; change some names (progn (setq meldingsoort "Oriëntatieverzoek") ) (progn (setq meldingsoort "Graafmelding") ) ) (setq meldingsoortlist (cons meldingsoort meldingsoortlist)) ) ) (setq meldingnrlist (vl-string-right-trim ", " (apply 'strcat (mapcar '(lambda (x) (strcat x ", ")) meldingnrlist)))) ; add comma's an remove last comma (setq meldingnrlist (vl-princ-to-string meldingnrlist)) ; make string of the result. (Result is one string with all elements of the lisp, seperated with a comma.) :-) Quote
Grrr Posted January 13, 2017 Posted January 13, 2017 You don't need this: (setq meldingnrlist (vl-princ-to-string meldingnrlist)) ; make string of the result. Because this is already a string: (setq meldingnrlist (vl-string-right-trim ", " (apply 'strcat (mapcar '(lambda (x) (strcat x ", ")) meldingnrlist)))) ; add comma's an remove last comma Quote
