Rudbeckia Posted January 13, 2017 Share Posted January 13, 2017 Hi folks I was working on a block edit in a cad file (cad 2012) and I saved the file as I was in the block editor. The file then suddlenly closed. Now when I reopen the file, there is nothing in model space but the block. All other work is going Its as if the file is stuck in the block editor but I am not in the block editor. The file is the same size, so I think the other stuff is there somewhere? Any thoughts much appreciated. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 13, 2017 Share Posted January 13, 2017 You might try to recover or use a .bak if you have one. This was a bug in AutoCAD 2012 and there is a hotfix HERE. Quote Link to comment Share on other sites More sharing options...
Rudbeckia Posted January 13, 2017 Author Share Posted January 13, 2017 thanks for the response ugh that's a pretty ****ty bug, I will try the bak file Quote Link to comment Share on other sites More sharing options...
