Need some modification in this Lisp...
Hello to all,
I found this Block Size Lisp from somewhere and it works fine. After running this Lisp it asks for Select Objects then hit enter for scale factor and give it the value for scale factor then hit enter and it scales selected blocks.
But I want this Lisp work in this way that after running this Lisp it asks for select objects and when you hit enter it automatically select the Scale Factor and the value of "0.02".
If someone can help me I'll be thankfull for that.
(defun C:SIZE (/ sngScaleFactor
                ssSelections
                strScaleOption
(princ "\nSelect items to size individually by their own insertion point: ")
(setq ssSelections   (ssget (list (cons 0 "ATTDEF,INSERT,MTEXT,TEXT"))))
(initget "I F")
(setq strScaleOption (getkword "\n[i]nsertion Scale or Scale [F]actor: "))
(initget 6)
(setq sngScaleFactor (getdist "\nEnter Scale Factor: "))
(vlax-for objItem (vla-get-activeselectionSet
                   (vla-get-activedocument
                    (vlax-get-acad-object)))
 (if (wcmatch (vla-get-objectname  objItem)
              "AcDbBlockReference,AcDbMInsertBlock")
  (if (= strScaleOption "F")
    (vlax-put objItem "xscalefactor" (* sngScaleFactor (vlax-get objItem "xscalefactor")))
    (vlax-put objItem "yscalefactor" (* sngScaleFactor (vlax-get objItem "yscalefactor")))
    (vlax-put objItem "zscalefactor" (* sngScaleFactor (vlax-get objItem "zscalefactor")))
    (vlax-put objItem "xscalefactor" sngScaleFactor)
    (vlax-put objItem "yscalefactor" sngScaleFactor)
    (vlax-put objItem "zscalefactor" sngScaleFactor)
   (vlax-put objItem "height" (* sngScaleFactor (vlax-get objItem "height")))
   (vlax-put objItem "height" sngScaleFactor)
(prin1)
                ssSelections
                strScaleOption
[color="royalblue"] ;(initget "I F")
;(setq strScaleOption (getkword "\n[i]nsertion Scale or Scale [F]actor: "))
;(initget 6)[/color]
(setq sngScaleFactor [color="red"]0.02[/color]) ; [color="red"]scale value[/color]
(prin1)
Blocked codes in blue color
try this lisp
A slight variation
(defun SIZE ( sngScaleFactor /
; (setq sngScaleFactor [color=red]0.02[/color]) ; [color=red]scale value[/color]
Then to call type (size 0.2) can change size this way
A slight variation
Hey BIGAL,
Dont get me wrong.
But why would you choose this solution, instead of just setting 'setq' to a forced number?
I tried this on annotative text..
somehow it put height at in it .. 'sngScaleFactor/annoscale'
Would be nice if could be worked out for annotative text.
Aftertouch You are correct the post was for 0.2 only. When you start reading many posts the first thing is that another requester asks "Can you add 0.2 or 0.4 as an option" "can I just have this added". Hence a more generic possibility for perhaps some one else that may read the post.
