Thunderspeed Posted January 17, 2017 Posted January 17, 2017 Hi all, I want to import a jpg image to autocad version 2007, then draw on it some additions and namings then have it back all in jpg form. How can I import the image into autocad 2007 ? Thanks in advance Quote
halam Posted January 17, 2017 Posted January 17, 2017 command : image .. should work. You can scale and rotate and manipulate it, draw it.. print it to jpeg. Quote
OMEGA-ThundeR Posted January 17, 2017 Posted January 17, 2017 don't know if that works in 2007, but you could just drag the image in and it should automaticly add as an xref. To be certain, internet says it doesn't work that way with 2007 LT, you have the full version? In the more 'official' and time consuming way you could also add an image via the eXternal Reference manager. Just bind a image instead of a DWG file. Quote
