alexdott Posted January 18, 2017 Posted January 18, 2017 Hello guys, I'm looking for a way to convert either a .png or .jpeg file to the file types .stp and .stl Is there a free way to do this for at least 4 files? Thank you for any guidance! -Alex Quote
ReMark Posted January 18, 2017 Posted January 18, 2017 Did you try doing an Internet search using search criteria similar to this....? "convert png to stp" ...or... "convert jpeg to stl" ...or... "convert png to stl" ...or... "convert jpeg to stp" Quote
alexdott Posted January 18, 2017 Author Posted January 18, 2017 Thank you for your prompt response ReMark, I did do several searches and found a few programs, but none of them seemed to be able to convert them to either file. Quote
ReMark Posted January 18, 2017 Posted January 18, 2017 Yep, a lot of promises made but very few actually kept. You might have to use more than two different programs to achieve the result you are looking for. However, I would surmise as you go through each conversion it must have some negative affect on the overall accuracy? Quote
TheCADnoob Posted January 18, 2017 Posted January 18, 2017 What are you trying to accomplish with this conversion? .stp and .stl are 3D formats (generaly) and .png and .jpeg are 2D raster. There will likely be no clean conversion out there. Quote
