I must commend you Mr. Watson, on both the quality and quantity of helpful information that is found here. I have never NOT gotten the help that was needed. Thank you very much Sir!!!
My issue today is that when I bring up CAD, there is a window telling me that I am currently running with Hardware Acceleration turned off.
I've read the explanation of the effects of using the "hardware acceleration" and am wondering if there is any real benefit to using it since I am not a high output shop and not doing any sophisticated modeling or rendering.
Run it however it works best for you.
If you do not have a supported display adapter and the correct driver, then hardware acceleration turn ON can actually give you much worse results.
