How to read polyline vert to file with name?
If the notepad file: "Desired" is indeed what you would like:
   Polyline Coordinate Writer
       by Lee McDonnell
         27.01.2009
; Version 2 ~ Polyline Writing Format Altered.
(defun c:plco2 (/ File oFile ss eLst Selss pName aEnt vLst i vNme)
 (vl-load-com)
 (if (setq File (getfiled "Create a Text File" "C:\\" "txt" 9))
     (setq oFile (open File "W"))
     (if (setq    ss (ssget (list    (cons 0 "POLYLINE")
   (if (getvar "CTAB") (cons 410 (getvar "CTAB"))(cons 67 (- 1 (getvar "TILEMODE")))))))
     (setq    eLst  (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
       Selss (ssadd))
     (foreach ent eLst
       (ssadd ent Selss)
       (sssetfirst nil Selss)
       (if    (not (setq pName (getstring t "\nSpecify Name for Selected Polyline >  ")))
         (setq pName (vl-princ-to-string ent)))
       (setq aEnt (entnext ent))
       (while (/= "SEQEND" (cdr (assoc 0 (entget aEnt))))
         (setq vLst (cons (cdr (assoc 10 (entget aEnt))) vLst)
           aEnt (entnext aEnt)))
       (setq i    (length vLst))
       (while (not (minusp (setq i (1- i))))
         (write-line
       (strcat    pName "\t"
           (rtos (car (nth i vLst)) 2 2) ","
           (rtos (cadr (nth i vLst)) 2 2) ","
           (rtos (caddr (nth i vLst)) 2 2) "\n") oFile))
       (setq vLst nil)
       (ssdel ent Selss)
       (sssetfirst nil nil)))
   (princ "\n<!> No Polyline Selected <!>")))
   (princ "\n<!> No File Selected <!>"))
 (close oFile)
 (princ "\n...Vertices Written to File...")
 (princ))
Then the above should do your bidding. :)
  • Replies 27
  • Lee Mac
    17
  • iztok13
    10
  • CarlB
    1
ok the the desire file is ok, But when i run plco2 lisp writen above i cant select poly, it say nothing selected????
please try the file wich i upload and try if you have the same problem?
I can't get to the file you uploaded...
Can you not attach the file?
Ahh, you are using (2D) LWPolylines - I shall alter the LISP accordingly :)
Here you are - just window the whole drawing to select polylines (as in your example).
       by Lee McDonnell
         27.01.2009
; Modified for use with LWPOLYLINES
(defun c:plco2 (/ File oFile ss eLst Selss pName aEnt vLst i)
 (vl-load-com)
     (if (setq    ss (ssget (list    (cons 0 "LWPOLYLINE")
       Selss (ssadd))
     (foreach ent eLst
       (ssadd ent Selss)
       (setq vLst (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget ent))))
         (write-line
       (strcat    pName "\t"
           (rtos (cadr (nth i vLst)) 2 2) "\n") oFile))
       (setq vLst nil)
       (ssdel ent Selss)
 (close oFile)
 (princ))
Ok I tested, This time I think it really works for me. im really glad that you help me. This routin will make my work much easier than time before.
Thank you again.
