Hello!
Im struggling with the modeling of a Computer fan. My idea is to make a fan with a diameter of 120 mm and to make it look somethin like the fan in the picture. 1.
To create the fan blades I have used a coil and then tried to make the soft edges using a sketch and then cuting it out (fillet did not work well because I could'nt get the shape I was looking for).
The thing that I ran upon was that when I used a circular patern it cut out things of the other fan blades and it al ended up in a mess..
Any suggestions on solutions?
Attach your file(s) here.
If you want the blades uniform thickness, then I would use a trimmed surface coil.
Then Thicken.
If you want non-uniform thickness then that becomes a bit more difficult using Loft.
Of course, create one blade and pattern.
Not quite the same as your design - but might give you some ideas.
http://www.cadtutor.net/forum/showthread.php?34738-Impeller-Headache&highlight=impeller
http://www.cadtutor.net/forum/showthread.php?42799-STUCK-on-impeller-vanes&highlight=impeller
This isn't inventor, and its really old, but here was a fan tutorial i probably did about 7 years ago in solidworks.
http://shift1313.wix.com/design-splash#!__tutorial-downloads
page 33 is where i make the blades and one method. I actually just did a plastic part design course for Pluralsight creating a pc fan. I did this with Fusion360 but the process is similar.
  • 4 weeks later...
Use sketch and loft to make one blade then use revolve to make the others.
