Hello to all
I am trying to modify a code that I have been using for placing block at certain distance from the start of the polyline.
What I would like to achieve is to have the very same block placed on the other side of the polyline (the same distance from the start to the first one) and to be able to select multiple polylines at once, as the code now works for one polyline.
Can anyone help me achieve this?
(defun C:dampers(/ ang cumm_dist dis dist_list leng obj pt)
 (vl-load-com)
;; build master list of the distances, starting from 0.0 - important!
(setq dist_list '(2.0))
(setq cumm_dist (apply '+ dist_list))
(setq dis 0.0)
(setq obj (vlax-ename->vla-object (car (entsel "\n >> Select profile >>"))))
(setq leng (vlax-curve-getdistatpoint obj (vlax-curve-getendpoint obj)))
;; check if pline length is not less than the cumulative distance
(if (< leng cumm_dist)
     (alert "Pline length is less then summary distance")
(while (< dis cumm_dist)
 (setq dis (+ dis (car dist_list)))
 (setq pt (vlax-curve-getpointatdist obj dis))
;;to insert block named "vibr":
;; get angle:
(setq ang (angle '(0 0 0)
	      (vlax-curve-getfirstderiv obj
		(vlax-curve-getparamatpoint obj pt))))
;;insert block:
 (vlax-invoke (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
   'InsertBlock pt "vibr" 1 1 1 ang);***
dampers.lsp
output.dwg
Try this, Works on multiple polylines :
(defun c:test (/ a b c d i)
 (vl-load-com)
 (princ "\n >> Select profiles >>")
 (if (and (setq a (ssget '((0 . "*polyline"))))
   (setq d (getreal "\nSpecify Distance Interval : "))
   (repeat (setq i (sslength a))
     (setq b (vlax-ename->vla-object (ssname a (setq i (1- i)))))
     (setq c (vla-get-length b))
     (if (> c d)
(foreach x (list (vlax-curve-getpointatdist b d)
		 (vlax-curve-getpointatdist b (- c d))
  (vla-insertblock
    (vla-get-modelspace
    (vlax-3d-point x)
    "vibr"
    1
    1
    1
    (angle '(0 0 0)
	     b
	     (vlax-curve-getparamatpoint b x)
