BHAInc
More efficient way to write specified code?
BHAInc
Is there a more efficient way to write the following code?
Thanks in advance for any suggestions.
(mapcar
   (function
       (lambda (l) (vl-catch-all-apply 'vla-addline l))
   (list
       (list (vla-get-paperspace (acdoc))
      (vlax-3d-point '(0.5 1.0 0.0))
      (vlax-3d-point '(8.0 1.0 0.0))
      (vlax-3d-point '(0.0 0.0 0.0))
      (vlax-3d-point '(8.5 0.0 0.0))
      (vlax-3d-point '(0.0 11.0 0.0))
      (vlax-3d-point '(0.5 10.5 0.0))
      (vlax-3d-point '(8.0 10.5 0.0))
      (vlax-3d-point '(8.5 11.0 0.0))
Share this post
Link to post
Grrr
(mapcar
 '(lambda (x) (entmakex (list '(0 . "LINE") (cons 10 (car x)) (cons 11 (cadr x)))))
     ((0.5 1.0 0.0) (8.0 1.0 0.0))
     ((0.0 0.0 0.0) (8.5 0.0 0.0))
     ((0.0 11.0 0.0) (0.0 0.0 0.0))
     ((0.5 10.5 0.0) (0.5 1.0 0.0))
     ((8.0 1.0 0.0) (8.0 10.5 0.0))
     ((8.5 0.0 0.0) (8.5 11.0 0.0))
     ((0.5 10.5 0.0) (8.0 10.5 0.0))
     ((0.0 11.0 0.0) (8.5 11.0 0.0))
EDIT:
For 2D points (on zero elevation), maybe something like this:
(mapcar
 '(lambda (x) (entmakex (mapcar 'cons '(0 10 11) (append '("LINE") (mapcar 'append x (mapcar 'list '(0. 0.)))))))
   ((0.5 1.0) (8.0 1.0))
   ((0.0 0.0) (8.5 0.0))
   ((0.0 11.0) (0.0 0.0))
   ((0.5 10.5) (0.5 1.0))
   ((8.0 1.0) (8.0 10.5))
   ((8.5 0.0) (8.5 11.0))
   ((0.5 10.5) (8.0 10.5))
   ((0.0 11.0) (8.5 11.0))
HTH, I was bored.
Edited by Grrr
Share this post
Link to post
BIGAL
Maybe make 1 big list ((pt1)(pt2)(pt1)(pt2).....) get length of the list then use repeat, Ok a question if its a 4 sided box just done twice why not use rectang 2 pts only required.
(setq lst  (list
(list 0.5 1.0 0.0)
(list 8.0 1.0 0.0)
(list 0.0 0.0 0.0)
(list 8.5 0.0 0.0)
(list 0.0 11.0 0.0)
(list 0.0 0.0 0.0)
(list 0.5 10.5 0.0)
(list 0.5 1.0 0.0)
(list 8.0 1.0 0.0)
(list 8.0 10.5 0.0)
(list 8.5 0.0 0.0)
(list 8.5 11.0 0.0)
(list 0.5 10.5 0.0)
(list 8.0 10.5 0.0)
(list 0.0 11.0 0.0)
(list 8.5 11.0 0.0)
(setq x (length lst))
(repeat (/ (length lst) 2)
(command "line" (nth (- x 2) lst) (nth (- x 1) lst) "")
(setq x (- x 2))
my preference 5 lines long
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(command "rectang" (list 0.5 1.0) (list 8.0 10.5))
(command "rectang" (list 0.0 0.0) (list 8.5 11.0))
(setvar "osmode" oldsnap)
Edited by BIGAL
Share this post
Link to post
Lee Mac
I would suggest two lists:
(mapcar
  '(lambda ( a b ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b))))
  '((0.5 1.0)(0.0 0.0)(0.0 11.0)(0.5 10.5)(8.0  1.0)(8.5  0.0)(0.5 10.5)(0.0 11.0))
  '((8.0 1.0)(8.5 0.0)(0.0  0.0)(0.5  1.0)(8.0 10.5)(8.5 11.0)(8.0 10.5)(8.5 11.0))
Share this post
Link to post
BHAInc
Excellent!
Thank you for all for the suggestions and replies, they're very helpful.
In the name of academic curiosity, is anyone able to suggest a more efficient way to write the code while using the "vla-addline" function?
Thanks in advance.
Share this post
Link to post
marko_ribar
Copy+pasted lists from Lee...
(mapcar (function (lambda ( a b ) (vla-addline (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point a) (vlax-3d-point b))))
Share this post
Link to post
Lee Mac
You realise that this is needlessly retrieving the Paperspace Container, Active Document Object and Application Object for every line created!?
These objects need only be obtained once and referenced locally, e.g.:
(   (lambda ( spc )
       (mapcar '(lambda ( a b ) (vlax-invoke spc 'addline a b))
          '((0.5 1.0 0.0)(0.0 0.0 0.0)(0.0 11.0 0.0)(0.5 10.5 0.0)(8.0  1.0 0.0)(8.5  0.0 0.0)(0.5 10.5 0.0)(0.0 11.0 0.0))
          '((8.0 1.0 0.0)(8.5 0.0 0.0)(0.0  0.0 0.0)(0.5  1.0 0.0)(8.0 10.5 0.0)(8.5 11.0 0.0)(8.0 10.5 0.0)(8.5 11.0 0.0))
Share this post
Link to post
Grrr
Also its a smart thing to avoid the point safearray conversion by using vlax-invoke, just like Lee did,
but for obtaining the container with model/paper space entities I think that this would be more suitable:
(or
 (setq
   acDoc (vla-get-ActiveDocument (vlax-get-acad-object))
   AcSpc (vlax-get acDoc (if (= acModelSpace (vla-get-ActiveSpace acDoc)) 'ModelSpace (if (= (vla-get-mSpace acDoc) :vlax-true) 'ModelSpace 'PaperSpace)))
 (vla-get-Block (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object))))
I mean either obtain the Mspace/Pspace by checking or directly access the block (I got used with the or funciton to write alternatives inside the code).
Share this post
Link to post
BIGAL
I tried to find a vla-addrectang does it exist ?
vla-addLightweightPolyline does exist, so can pass the 4 points.
Share this post
Link to post
Grrr
Yeah, basically the result from the RECTANGLE command is a lwpolyline, i.e. when you dump a rectangle the first row is:
; IAcadLWPolyline: AutoCAD Lightweight Polyline Interface
just like entgetting the same thing should result (0 . "LWPOLYLINE"), so theres no such thing as rectangle method or entmaking an rectangle.
But you're leaving the idea for creating such subfunction that would add/emake rectangle lwpoly from a 2 points argument (lowerleft upperright).
EDIT: BTW heres another (with command calls) similar to yours:
 (lambda (c)
   (setvar 'cmdecho 0)
   (foreach x '(((0. 0. 0.) (8.5 11 0)) ((0.5 1.) (7.5 9.5 0)))
     (command "_.RECTANGLE" "_non" (car x) "_non" (mapcar '+ (car x) (cadr x)))
   (setvar 'cmdecho c)
 (getvar 'cmdecho)
Edited by Grrr
Share this post
Link to post
BHAInc
Thank you again for all of the suggestions and replies. Very informative.
Share this post
Link to post
BIGAL
Your right Grr I think the bottom line without continuing on is "do you want individual lines or rectangs" so both have been covered with different methods..
Share this post
Link to post
