Hi,
I got a lisp from google browsing, this lisp helps to remove spaces from text in drawing, but I got around 100 drawings where in drawing in particular layered texts contains unwanted spaces. In my drawings layer "Text" and color "green" texts contents unwanted spaces I want to remove these particular spaces using lisp, but I have only space removing lisp. can we make a lisp to modify remove spaces from particular layer and color texts in all drawings at a time. here I am placing lisp which I have got from net.
(defun C:REMSPC (/ ss i elist txt n)
(setq ss (ssget '((0 . "TEXT"))))
(if ss
(setq i (1- (sslength ss)))
(while (>= i 0)
(setq elist (entget (ssname ss i))
txt (cdr (assoc 1 elist))
i (1- i)
(while (= (substr txt 1 1) " ")
(setq txt (substr txt 2))
(setq n (strlen txt))
(while (= (substr txt n 1) " ")
(setq n (1- n))
(setq txt (substr txt 1 n))
(entmod (subst (cons 1 txt)(assoc 1 elist) elist))
(alert "No TEXT selected.")
___
I doubt it would be possible to remove the space in all drawings at ONE time. Most likely you would have to do a batch operation possibly employing a script that would process an entire folder of drawings.
Hi,
Please modify your post to add code tags READ THIS
I could write the codes to remove the space in all your target drawings but unfortunately I will not write them on voluntary time.
So hit this >> LINK to contact me if you'd like me to write the program for you.
