ktbjx Posted February 10, 2017 Posted February 10, 2017 we need an easier way to outline all these wireframes given to us by other team. and we are dealing with multiple files. what we currently do now is manually snapping polylines to it, and its very time consuming. please help us do this faster? TRIM.dwg Quote
steven-g Posted February 10, 2017 Posted February 10, 2017 The outline you have drawn doesn't appear to relate to any of the other objects in the drawing? Do you draw around the outer limits of the 3D faces in the view as it is, or do you pick points based on other factors. Quote
Roy_043 Posted February 10, 2017 Posted February 10, 2017 Try ECO - External contour of objects. Quote
BIGAL Posted February 11, 2017 Posted February 11, 2017 They are 3d objects so how do you work out a boundary which faces to use the vertical the top etc. Are you doing a pline based on the view direction ? I dont think you question has enough detail. Quote
