pawcyk Posted February 16, 2017 Posted February 16, 2017 (edited) Hello everybody. Can anyone halp me with this code: defun getfencesel (en flt / fe ss) (vl-cmdf "_ZOOM" "_E") (setq ss (ssadd en)) (setq fe (acet-list-remove-adjacent-dups (acet-geom-object-point-list en 0.05)) ss (ssget "_F" fe flt) ) (vl-cmdf "_ZOOM" "_P") ss ) Maybe someone known how it rewrite into normal Autolisp or Vlisp?? Edited February 17, 2017 by rkmcswain Added [CODE] tags Quote
Grrr Posted February 16, 2017 Posted February 16, 2017 Heres my attempt: ; (sssetfirst nil (GetFenceSel (car (entsel)) '((0 . "*TEXT")) 3)) ; (sssetfirst nil (GetFenceSel (car (entsel)) nil 3)) (defun GetFenceSel ( e flt prec / DivideCurveAtInc Trap pL ll ur SS ) (defun DivideCurveAtInc ( i c / TotLen d PtLst ) (if (and (numberp i) (not (or (zerop i) (minusp i))) (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getEndParam (list c)))) (<= i (setq TotLen (vlax-curve-getDistAtParam c (vlax-curve-getEndParam c)))) ) (progn (setq d 0.0) (while (<= d TotLen) (setq PtLst (cons (vlax-curve-getPointAtDist c d) PtLst)) (setq d (+ d i)) ); while (setq PtLst (reverse PtLst)) ); progn ); if PtLst ); defun DivideCurveAtInc (defun Trap ( f L / r err ) (if (setq err (not (vl-catch-all-error-p (setq r (vl-catch-all-apply f L))))) (if r r err)) ) (cond ( (not (setq e (Trap 'vlax-ename->vla-object (list e)))) (princ "\nNo object provided.") ) ( (not (Trap 'vla-GetBoundingBox (list e 'll 'ur))) (princ "\nInvalid object.") ) ( (or (and (Trap 'vlax-curve-getEndParam (list e)) (setq pL (mapcar '(lambda (x) (reverse (cdr (reverse x)))) (DivideCurveAtInc prec e))) ) (setq pL ( (lambda ( x / p1 p2 ) (setq p1 (car x)) (setq p2 (cadr x)) (list p1 (list (car p1) (cadr p2)) p2 (list (car p2) (cadr p1))) ) (mapcar '(lambda (x) (reverse (cdr (reverse (safearray-value x))))) (list ll ur)) ) ) ); or (vla-ZoomWindow (vlax-get-acad-object) ll ur) (and (setq SS (ssget "_F" pL flt)) (ssadd (vlax-vla-object->ename e) SS) ) (vla-ZoomPrevious (vlax-get-acad-object)) ) ); cond SS ); defun GetFenceSel (vl-load-com) (princ) Where 'prec is the unit increment for the curve to be divided. HTH Quote
Lee Mac Posted February 17, 2017 Posted February 17, 2017 You could use this in place of acet-geom-object-point-list. Quote
pawcyk Posted February 17, 2017 Author Posted February 17, 2017 (edited) I've put wrong code. This is corect: (defun getfencesel (en flt / fe ss) (acet-ss-zoom-extents (setq ss (ssadd en))) (setq fe (acet-list-remove-adjacent-dups (acet-geom-object-point-list en 0.05)) ss (ssget "_F" fe flt) ) (vl-cmdf "_ZOOM" "_P") ss ) The all lisp is here: https://www.theswamp.org/index.php?topic=9042.465 File: TriangV0.6.7.LSP by ymg Becouse my CAD don't have Acad Express Tools so I have to change the TriangV0.6.7.LSP. I've changed the parts with function: pragma vl-times acet-ui-progress ..adne command TIN is working, but PROF still isn't. I've put grrr code instead fragment with error but it doesn't work. My knowledge of this is over. I'm still using COMAND I will be grateful for your help. Pawcyk Edited February 17, 2017 by rkmcswain Added [CODE] tags Quote
SLW210 Posted February 17, 2017 Posted February 17, 2017 Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[NOPARSE] Your Code Here[/NOPARSE] = Your Code Here Quote
pawcyk Posted February 17, 2017 Author Posted February 17, 2017 Can I change my posts now? If not I will try do it corectly in the future. My english isn't as good as I want thats why I could missed it. Pawcyk Quote
pawcyk Posted February 20, 2017 Author Posted February 20, 2017 Lee Mac your code is working, thank you very much. Quote
Lee Mac Posted February 20, 2017 Posted February 20, 2017 Lee Mac your code is working, thank you very much. Excellent - you're welcome! Quote
