Is there a way to suppress the scale and rotation sub-prompts after you place a block from the ADDSELECTED command? Thanks in advance!
-TZ
probably have to do a macro
addselect pause ;;;
didn't test but it would be something like that
Macro may be the way to go but you could use lisp also like this.
(defun C:ADDSELBLK ()
 (setq blk (entsel "Select Block to used Add Selected with "))
 (setq pt1 (getpoint "\nChoose a Point : "))
 (command "ADDSELECTED" blk pt1 "" "" "")
It needs work to only allow you to select blocks
Sunny, is there any way to accomplish this without LISP? rkent, thanks again for your help. I will attempt a Macro.
-TZ
