broncos15 Posted February 24, 2017 Posted February 24, 2017 So I am trying to update a block (named DRN-BASIN) based on a csv file that has four columns. The first column has Basin No., next is ACRES, next is CO-EF, and next is CO-EF-2. I need to update the blocks in my drawing based on the corresponding Basin No. attribute of the block. All attributes for the block correspond to one of the columns in the Excel csv file. Where exactly should I get started on this to iterate over the blocks and find each block attribute? Quote
BIGAL Posted February 24, 2017 Posted February 24, 2017 1st Lee-mac has a csv to a "list" for each line so you get 4 values. So many block examples here start with a ssget (2 . Blockname) Just search through the selection set and check the attribute TEXTSTRING using the Tag name, if its the one then update the attribute. This has multiple tags to be updated ; update the COGG title blocks in a dwg ; change the 410 to layout name ;;-------------------=={ Parse Numbers }==--------------------;; ;; ;; ;; Parses a list of numerical values from a supplied string. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - [url="http://www.lee-mac.com"]www.lee-mac.com[/url] ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; s - String to process ;; ;;------------------------------------------------------------;; ;; Returns: List of numerical values found in string. ;; ;;------------------------------------------------------------;; (defun LM:ParseNumbers ( s ) ( (lambda ( l ) (read (strcat "(" (vl-list->string (mapcar (function (lambda ( a b c ) (if (or (< 47 b 58) (and (= 45 b) (< 47 c 58) (not (< 47 a 58))) (and (= 46 b) (< 47 a 58) (< 47 c 58)) ) b 32 ) ) ) (cons nil l) l (append (cdr l) (list nil)) ) ) ")" ) ) ) (vl-string->list s) ) ) (defun ah:sheetupdate1 ( / ss1 len lay plotabs tabname dwgname oldtag1 oldtag2 oldtag3 oldtag4 oldtag5) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for lay (vla-get-Layouts doc) (setq plotabs (cons (vla-get-name lay) plotabs)) ) (IF (NOT AH:getval3)(LOAD "GETVALS")) (AH:getval3 "Please enter dwg number" 12 9 "Please enter version for all sheets <Cr> no change" 8 5 "Please enter line1 details " 40 38 ) (setq dwgname VAL1) (setq newstr4 VAL2) (SETQ NEWSTR6 VAL3) (princ "0") (setq len (length plotabs)) (setq x 0) (setq bname "DA1DRTXT") (repeat len (setq tabname (nth x plotabs)) (if (/= tabname "Model") (progn (setvar "ctab" tabname) (command "pspace") (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 tabname)))) (setq dwgnum (Lm:parsenumbers tabname)) (setq sheetnum (car dwgnum)) (setq oldtag1 "SHT_NO") ;attribute tag name (setq newstr1 (rtos sheetnum 2 0)) (setq oldtag2 "DRG_NO") ;attribute tag name (setq oldtag3 "PROJ_NO") ;attribute tag name (setq newstr3 dwgname) (setq oldtag4 "REV_NO") ;attribute tag name (setq oldtag5 "SHEETS") ;attribute tag name (setq oldtag6 "STREET") ;attribute tag name ; if less than 10 (if (< (car dwgnum) 10.0) (setq newstr2 (strcat dwgname "-D0" (rtos sheetnum 2 0))) (setq newstr2 (strcat dwgname "-D" (rtos sheetnum 2 0))) ) (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 0 )) 'getattributes) (if (= oldtag1 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr1) ) ; end if (if (= oldtag2 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr2) ) ; end if (if (= oldtag3 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr3) ) ; end if (if (and (/= newstr4 nil) (= oldtag4 (strcase (vla-get-tagstring att))) ) (vla-put-textstring att newstr4) ) ; end if (if (= oldtag5 (strcase (vla-get-tagstring att))) (vla-put-textstring att (rtos (- len 1) 2 0)) ) ; end if (if (= oldtag6 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr6) ) ; end if ) ; end foreach ) ; end progn ) ; end if (setq x (+ x 1)) ) ; end repeat (setq ss1 nil) ) ; end defun ah (ah:sheetupdate1) (princ) Quote
BIGAL Posted February 24, 2017 Posted February 24, 2017 Almost forgot you can go direct from excel if you want removing the make csv step. Quote
