How do I set an attribute value that is within a block to a variable using a lisp statement? I do not want any user input to be used, it needs to be scriptable. There will only be one instance of the block in the drawings. If you need more information, I will gladly give it. Thanks
Welcome to CADTutor. :)
Have a play with the following and you should be able to see the list of attributes in the command line;
(defun c:Test ( / s sn e lst)
 (if (setq s (ssget "_X" '((0 . "INSERT")(66 . 1) (2 . "MyBlock")))) [color="red"];; Change the MyBlock name to your block name[/color]
     (setq sn (ssname s 0)) [color="red"];; Assumed to run on one block instance / reference.[/color]
     (while (= "ATTRIB" (cdr (assoc 0 (setq e (entget (setq sn (entnext sn)))))))
       (setq lst (cons (cdr (assoc 1 e)) lst))
 lst [color="red"];; list of attributes values if available.[/color]
I ran your code with my block name inserted. I then type test in the command line and the only thing I get back is nil. I am not sure what I am supposed to do here.
Is you block dynamic or regular?
And how did you add your block name into the codes?
Another (just for fun) :
(defun GetBlkAttVals ( bnm / o L )
 (if (and (setq o (FirstBlkOccurrence bnm)) (setq L (vlax-invoke o 'GetAttributes)) )
   (mapcar 'vla-get-TextString L)
); defun GetBlkAttVals
; recursive
(defun FirstBlkOccurrence ( n / rec )
 (defun rec ( b n i / o )
   (cond
     ( (vl-catch-all-error-p (setq o (vl-catch-all-apply 'vla-item (list b i)))) (prompt "\nError") )
     ( (and (vlax-property-available-p o 'EffectiveName) (= n (vla-get-EffectiveName o))) o)
     ( (rec b n (1+ i)) )
   ); cond
 ); defun
 (rec (vla-get-Block (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))) n 0)
); defun FirstBlkOccurrence
; iterative
(defun FirstBlkOccurrence ( n / i->L b o )
 (defun i->L ( i / L ) (if (eq 'INT (type i)) (repeat i (setq L (cons (setq i (1- i)) L)))) )
 (setq b (vla-get-Block (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))))
 (vl-some
   (function
     (lambda (x)
       (if
         (and
           (setq o (vla-item b x))
       o
   (i->L (vla-get-Count b))
 ); vl-some
Usage example - (where the blockname is case-sensitive) :
(GetBlkAttVals "MyBlockName")
My block is static. I inserted my block name like so:
(if (setq s (ssget "_X" '((0 . "INSERT")(66 . 1) (2 . "FCA_TB")))) ;; Change the MyBlock name to your block name
Nothing is special in my posted codes above, so if you can upload a sample drawing that would be great to check that out closely.
