Marvic SoftSolutions New Text Editor and Autocad 2015
Hi,
I have a bunch of lisp routines I have been using for eons like since R13 days, and one of the lisp routines does not work and wonder if anyone else uses Marvic's software and have had the same issue and possible solution, this did work on AutoCAD 2010 and MCAD2010, but recently switched computers with 2015 installed.
on text I get the normal dialog:
h+UVfX32tXxbwAAAABJRU5ErkJggg==
but trying it on a piece of Mtext I get the following in the command line:
Command: NT
Select objects: 1 found
Select objects:
*Cancel*
Unknown command "DDEDIT". Press F1 for help.
Any ideas, as I really like the older editor, I know you can double click, but hard to break old habits
Regards,
Ok I tried to attach a image and for some reason it won't upload it?
anyhow the dialog would have the text as is and a place to rewrite or edit line.
thanks again,
