I'm trying to create a DXF that contains a single rectangle of varying sizes through C#. Right now our CNC operators open up a cut file, stretch the file to the proper dimensions, save as a DXF and then open that file to be cut.
Because I have some C# code that runs during the order entry process, I'm trying to generate the cutfile at that time, rather than relying on the operator manually modifying a couple dozen cut files every day.
Is it possible to create a DXF file of a rectangle simply through c# code? Any help, code examples or just a point in the right direction would be greatly appreciated.
DXF code is a plain text file so it can be written in c# its understanding the pattern or sequence of codes
Why would you not just look at some you already have a DXF has all sorts of info in it but it can also be extremely short and just contain relevent information like your 4 lines.
Something like this is 1 line
AcDbEntity
8
0
100
AcDbLine
10
100.0
20
100.0
30
0.0
11
0.0
21
100.0
31
0.0
Edited by BIGAL
Didn't know DXF was plain text! Problem solved. Thanks so much. DKT
Sometimes the answer stares us in the face. :lol:
Just write a few functions line, arc & circle etc that write the correct dxf code.
Google DXF codes you should be able to find all the descriptions.
Looking at the _DXFOUT command may also be useful. It has the option to export only selected entities.
  • 2 weeks later...
BIGAL is on the money.
If you can, emit the simplest DXF standard that the consuming software will tolerate (R12 DXF or even much earlier, say v2.6 before they introduced the entity handle)
ACAD added a heap of interrelated cruft to later versions that is totally irrelevant in specifying simple cutter paths.
