Hello everyone,
Is it possible to run Alisp/Vlisp in the Autocad 360 mobile App?.
Edited by aloy
Since I couldn't get a reply from my regular site I tried to get it from the horse's mouth. And here is what they say:
diting dwg files
Options
13 Views, 2 Replies
03-04-2017 05:03 AM
Hello everyone,
Is it possible to edit AutoCAD drawings in A360 and also will it be possible to run Alisp/Vlisp files sometime in the future?.
Thanks,
AloyH
Solved! by bud.schroeder. See the answer in context.
Kudo
Hello Aloy,
Thanks for posting your question to the fourm. A360 is not an editor, it is a collaboration tool. You will need AutoCAD, AutoCAD LT, an AutoCAD based vertical, or AutoCAD 360 Pro to edit your drawings.
You can check out the AutoCAD 360 Mobile product as well, here is a link to the WEB Site and the Forum.
AutoCAD 360 Pro Mobile:
AutoCAD 360 Forums:
We also have Fusion 360 that is an excellent program, you can check that out here.
Autodesk Fusion 360:
Autodesk Fusion Forums:
Hope this helps and have a great weekend.
Add Tag...
REPLY
Kudo
Success! Click to go to your post.
bud.schroeder
441 Kudos
470 Solutions
21 Ideas
Post 2 of 3
Report
Solution!Re: Editing dwg files
Options
03-04-2017 06:52 AM in reply to: AloyH
Hello Aloy,
AutoCAD 360 Forums:
Bud Schroeder
Autodesk Inc.
A360 Blog
A360 Tips, Tricks & Tutorials
A360 Idea board
Everyone's Tags: A360autocadautocad 360Fusion 360questionView All (5)
Add Tag...
REPLY
Kudo
AloyH
Post 3 of 3
Report
Options
03-04-2017 01:42 PM in reply to: bud.schroeder
Hello bud.schroeder,
Thanks for the reply. However for me to take your reply as the complete solution I need the answer for the second part as well. My understanding is that when we edit we are using the commands to do whatever we want to do. In the same way why not allow the users to load and run Alisp/Vlisp files? and when will that happen?.
Regards,
AloyH
The hybrid, Autocad Fusion 360 doesn't say whether it can run Alisp/Vlisp files
I am not sure whether I am contravening the policy of posting.
Thanks.
Edited by aloy
