pawcyk Posted March 7, 2017 Posted March 7, 2017 Good day. I'm trying to do an operation on many 3DFACEs. I need to change vertex like this: before: V1: x1=5.12345678 y1=3.23456789 z1=7.42345678 after: V1: x1=5.12000000 y1=3.23000000 z1=7.42000000 (defun c:zz () (vl-load-com) (if (setq ssSelections (ssget (list (cons 0 "3DFACE")))) (repeat (setq intCount (sslength ssSelections)) (setq intCount (1- intCount) entSelection (ssname ssSelections intCount) lstEntity (entget entSelection) objSelection (vlax-ename->vla-object entSelection) ) ;Vertex 1 (setq wierzcholek1 (assoc 10 lstEntity)) (setq x1 (nth 1 wierzcholek1)) (setq y1 (nth 2 wierzcholek1)) (setq z1 (nth 3 wierzcholek1)) ;Vertex 2 (setq wierzcholek2 (assoc 11 lstEntity)) (setq x2 (nth 1 wierzcholek2)) (setq y2 (nth 2 wierzcholek2)) (setq z2 (nth 3 wierzcholek2)) ;..... ;change point (setq nowaDef (subst (cons 10 (list (atof (rtos x1 2 2)) (atof (rtos y1 2 2)) (atof (rtos z1 2 2)) ) (assoc '10 lstEntity ) lstEntity ) )) (setq nowaDef (append lstEntity (list (cons 10 (list (atof (rtos x1 2 2)) (atof (rtos y1 2 2)) (atof (rtos z1 2 2)))) ) ) ) (entmod nowaDef) ;podmiana punktu 2 (setq nowaDef (subst (cons 11 (list (atof (rtos x2 2 2)) (atof (rtos y2 2 2)) (atof (rtos z2 2 2)) ) (assoc '11 lstEntity ) lstEntity ) )) (setq nowaDef (append lstEntity (list (cons 11 (list (atof (rtos x2 2 2)) (atof (rtos y2 2 2)) (atof (rtos z2 2 2)))) ) ) ) (entmod nowaDef) );end repeat );end if (print) );END Could anyone tell me what i'm doing wrong? Quote
Jef! Posted March 7, 2017 Posted March 7, 2017 Hi there! First of all, you have a misplaced parenthesis at 2 places in your code it should be (setq nowaDef (subst (cons 10 (list (atof (rtos x1 2 2)) (atof (rtos y1 2 2)) (atof (rtos z1 2 2)) ) ) (assoc '10 lstEntity) lstEntity ) ) Right after that if you entmod it, the result is shown.. BUT after that when you iterate for the 2nd vertex, you start with lstentity variable, which contain points before the first entmod, so you revert them back. Without knowing exactly what you are after, let'S just say that I don't get what you are trying to achieve with the part when you append. -retrieve list entity -subst all the things you need -THEN entmod. more calls to entmod are useless, and you would need to use the entmoded list instead of the original one. Cheers Quote
BIGAL Posted March 8, 2017 Posted March 8, 2017 An alternative to rtos and atof I would make it a tiny defun (2dec X) 123.4567*100 fix 12345.67 /100 =123.45 Not sure which is faster on a big data set. (defun 2dec ( x / ) (/ (fix (* x 100.)) 100.0) ) ; to use ; (setq x2 (2dec x2)) ; or ;(list (2dec x) (2dec y) (2dec z)) Have a look at this as well may be usefull (setq obj (vlax-ename->vla-object (car (entsel "\nPick 3dface")))) (setq pointls (vlax-safearray->list (vlax-variant-value (vla-get-Coordinates obj))) ) Quote
