I am a 9th grade student and I am working on a shed. I am in need of some help. :cry: Every time I try to extrude a board on a work plane directly on the header it jumps clear away from the shed. Any ideas? Thanks.
Welcome to CADTutor Levi. :)
Sorry I can't help you, as I don't use Inventor, but be patient, somebody will help get you back on the tracks.
Extrude the boards, and then assemble them the same way that you build a shed IRL
Post what you've got.
If you can attach your files or take a screen shot using Snipping Tool (or the old timer way is to press Ctrl + PrtScn (up by the F12 key usually), open up Paint or other drawing program, paste with Ctrl + V, crop out anything sensitive, save). The more information you provide the more we can help, even hand sketches with a picture taken on your phone would work. Way to start young, keep it up it's the start to an interesting profession.
